Middle of the night crazy idea
After a rough night last night, i woke up in the middle of the night and thought, my cellphone is very quiet and can never hear it in my car due to loud music. I have a no slip pad in the center console but still hard to see the phone light up
Heres my idea. Create some kind of device that catches cellphone frequencies so when you get a messege or a call, some kind of LED or bright light starts flashing.
What do you think of this million dollar idea, can it work?
I agree with you. It was nice when I saw it lit up when I didn't hear my phone rang.
Actually they had something like that. It was those see-through helicopter that lit when you had an incoming call. I had it when I had a nokia 5xxx series (about 3 years ago) with cingular. I think it worked with certain phone/carrier, not sure
I'll see if I can find that helicopter
My phone does not have an external antenna. And the light up batteries drain your battery. They are quite abnoxious.
Putting a little LED bulb by the mid console vents would surely get my attention. Anyone???
My buddy is an electrician and i what he told me was if my phone has an led light or any kind of light...a light with an output, he could tap into the circuit and have a plug in a headphone jack to the external led light which would cause it to flash with an incoming call or messege....i hope this makes sense to you like it kinda did to me
Unfortunately i don't have a separate light so i can't do it. Just thought i'd throw that out for you guys
Simplest solution is to mount it somewhere in your line of site. There are several ways you can mount a cell phone. Velcro might be the simplest and easiest to remove in the future. But there are a ton of cell phone holders available almost anywhere. Or, a lot of cell phone companies make hands free kits that you wire into your car. A lot of those will have a cell phone mute option for most aftermarket stereos.
there are things out there that can do that, check ebay, like phone holders, only problem with them is that you have to have GSM technology, (cdma won't work as well for some reason) and everytime it "searches" for a signal it will light up even though there is no call coming. i'm also sure you're local ricer store will have the "broadway" rear view attach mirror that has a light up thing in it.
