Nakamichi headunit is Possesed!
I just purchased a gs400 2 weeks ago. Everything worked at first and now my cd player works first thing in the morning and after 30 minutes or less the display freezes and it cuts off. I had the cd changer(pioneer) checked and it worked fine. I had the radio checked and it worked fine. I even had them removed from the car and just connected on the seat and it played fine. Once re-inserted into the car after about 10 minutes and same symptoms. I really enjoy the sound and performance when it works but I cannot continue like this! I believe it has a correlation between the heat and the radio or wiring but I
just cannot pinpoint the problem. Has anyone gone through this before? I have noticed that when it is cold it actually functions better which is why I believe it has something to do with the heat of the car.
Thanks for all the help and information- however the resolution to my problem was my key. I had a replacement key cut and it solved the (cd changer??) issue. Very wierd but it is true. Thanks CL!
