Installing neon
Old Jul 23, 2006 | 09:27 PM
LexOnDubz's Avatar
LexOnDubz
Default Installing neon
Sup everyone, I want to install some neon lighting inside my trunk. What is the best way to do this. Every neon comes with a cigarette lighter plug. Do I cut off the neon plugs and connect them to a switch and then run the switch to power or is there another way to do it. I want to install about 5-6 small neons. Please let me know.
Thanks
Old Jul 23, 2006 | 10:56 PM
vin 78's Avatar
vin 78
You could hook up all your neons to a relay. You could use either a physical switch or the remote wire for the "switching" wire for the relay. Don't forget to use a fuse it BTW.
For the cigarette lighter plug, the center prong is the positive and side prong are the negative.
Old Jul 24, 2006 | 05:16 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
calm down, no need to be rude.
he is putting neon into his TRUNK, for the custome enclosure he has on what appears to be a show car more than a DD.
most 12-18" neon kits come with regular wiring, not cigarette plugs, but either way, you have to run the wiring to the front of the car to the battery, fuse it, and hook it up.
Old Jul 24, 2006 | 08:22 AM
MoreMGD32's Avatar
MoreMGD32
you could also catch power from the trunk light this way your not using a switch to toggle power on and off. when you open and close the trunk this light will turn on and off. as stated above make sure you use a fuse.
or you can even catch power from the trunk light and use a switch so when the trunk is on you can still turn it off if you want
D3V3LOP3R
Feb 4, 2015 09:45 PM
SC400slide
Jan 19, 2015 04:49 PM
mk4r34
Feb 22, 2012 09:39 PM
JSwenis
Lighting
21
Nov 29, 2010 03:06 PM
hellasboy
Jan 10, 2002 07:38 AM
