Suuwoofer 1992 SC300
Old Feb 15, 2006 | 07:37 AM
rawdog's Avatar
rawdog
Default Suuwoofer 1992 SC300
Can I hook an aftermarket amp to the factorry subwoofer?
Old Feb 15, 2006 | 08:56 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Most likely, but I would advise against it. With a more powerful amp, that 14 year old sub will blow inside of a week. Makes more sense to drop in a new sub along with the new amp.
Old Feb 15, 2006 | 09:42 AM
rawdog's Avatar
rawdog
Default New Sub!
So I can put my new sub woofer into that Spot?
Old Feb 15, 2006 | 10:00 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Sure! As long as your new sub is a free-air model and you'll also need to confirm the mounting depth since the gas tank on our SC's is right beind the back seat!
You may also need to build a baffle to raise the new sub up a bit to clear the fuel sending unit at the top of the tank.
Also, this is the easy one, ensure the replacement speaker is the same size as the old one.
If you were plannign to use a speaker designed for an enclosure, put your enclosure in the trunk and remove the stock sub completely (leaving the hole), to allow for the bass to port into the cabin of the car.
Old Feb 15, 2006 | 10:44 AM
soarer1023's Avatar
soarer1023
well i have the a rockfort amp wire up to the stock sub right now, and it knocks pretty damn good, i don't remember what spec i have on the amp, coz my friend just gave it to me and i just hook it up without even looking, hehe, but yeah it is definitly not the best setup, but works well, just don't over power the amp for the stock sub that we have and that's about it.
Old Feb 15, 2006 | 02:45 PM
$C300's Avatar
$C300
If your going to wire up a after market amp and all that good stuff why don’t u just get a nice 10" after market woofer in a nice compact box throw it in the corner of ur trunk and just remove the stock woofer.
just my $0.02
kayrohit12
Apr 11, 2013 09:56 AM
vicestan
May 24, 2005 10:06 AM
Hockey2315
GS - 1st Gen (1993-1997)
Aug 31, 2004 12:49 AM
sc300n00b
12
Jun 24, 2004 08:53 PM
Phoenix88
Jan 27, 2003 05:12 PM
