No Remote Wire Signal
Old Feb 9, 2006 | 01:37 PM
krow_01's Avatar
krow_01
Default No Remote Wire Signal
I disconnected my aftermarket amp (for subs) to move it to a more secure and discrete location in my trunk. While everything was disconnected, the remote wire touched bare metal and then immediately the stereo completely shut off, the antenna went down and the changer no longer is in standby mode (No light). However, the changer will still spit out the magazine when i push the button to eject it. Everything else electronic in the car works as it should. The only things that don't work are what runs on that Remote Signal line.
Any idea what could be happening here?
Old Feb 9, 2006 | 01:53 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
Welcome to CL.
First let me say that this should be in the electronics section. A mod will move this for you.
Next, this may sound simplistic, but since you didn't state that you did......I'm assuming you have not checked your fuses. One fuse box is one the kick panel by your left foot (drivers side of the car). The other is under the hood, behind the battery moving towards the cabin.
Start there.
Old Feb 11, 2006 | 01:04 AM
krow_01's Avatar
krow_01
I had checked the fuse box under the hood, but I didn't know about the set by the kick panel. It was a fuse. Thanks for the help
Old Feb 11, 2006 | 10:01 AM
vin 78's Avatar
vin 78
Check out the owners manual, it should indicate ware the radio fuse is located.
Sheehan1p
Jan 15, 2010 03:42 PM
pwrdbyrice
Aug 19, 2008 09:51 PM
VTLexus
Jun 27, 2008 08:40 PM
kyle8744
13
Jul 23, 2004 09:00 AM
Evillex
Apr 28, 2004 04:42 PM
