LS400 Pioneer Changer Problem
Hi Guys
My Pioneers stacker in my 91 LS is making a clicking/slipping sound when it loads the cartridge contents. Once it goes through/tries to/ the loading procedure, Err comes up on the head unit.
Any advice?
Any advice?
psls400,
The clicking/slipping sound is normal. If you didn't hear anything at all, that could be signs of a bad spindle motor. You're hearing the unit trying read a disk from the cartridge. When is the last time you had the unit cleaned at an authorized Pioneer repair center? I think most dealers will just charge you for replacement...which is expensive. Pioneer still has the service manual for the unit...about $45 if I remember correctly.
I had the same problem on my 1990. I pulled the unit and had it cleaned at a Pioneer facility...works as designed now.
Rod G
Rod G
Rod G,
Thanks for the advice. I have the same clicking/err problem in my 1990 LS400. Are there any tricks involved in pulling the unit, other than removing the obvious screws?
Thanks,
Paul
(my new return address: phampel@post-dispatch.com)
Thanks,
Paul
Bradster
Apr 29, 2003 02:40 PM
JohnnyBlaze
May 31, 2002 09:36 AM
flexlex
Dec 10, 2001 05:16 AM
