Would Like Sub/amp Help!!
Old Feb 1, 2005 | 01:00 AM
beez43's Avatar
beez43
Default Would Like Sub/amp Help!!
i want to add some bass to my gs300 and replace the stock sub with an aftermarket one with the addition of an amp as well. i was wondering if there is a way to tap into the stock nak amp outputs for the sub and use it for a crossover or something for the amp. i do not really care for getting an aftermarket deck or components because im happy with them as it is and also i like the use of my cd changer being in my front glove compartment. i saw a post a little bit ago dealing with someone putting a diamond audio sub in the stock area and just running the sub from that stock spot.. PLEASE HELP ME OUT GUYS!!! im very lost in sounds now... and also, do i have to consider what ohms are needed for the diamond audio m6 10 inch sub?? the one i was looking at was a 4 ohm sub.. its a nice sub and would do well.. PLEASE HELP!!!!
Old Feb 1, 2005 | 07:16 PM
rgarjr's Avatar
rgarjr
To do the sub upgrade you would need a sub that is free air, an amplifier, and a line level converter You can tap into the sub wires to hook up your line level converter and then feed the rca outputs to your aftermarket amp. You of course need to run power cable from the battery to the amp and also ground the amp too and hook remote turn on.
Old Feb 1, 2005 | 10:50 PM
beez43's Avatar
beez43
would a diamond audio m6 sub cut it?
Old Feb 2, 2005 | 05:13 PM
FireCode's Avatar
FireCode
YES. M6=
vboi4life
Jun 14, 2013 05:41 AM
1supra
Nov 16, 2011 02:52 AM
QuachmanES
May 15, 2010 11:33 AM
