Convertible top issue
Old Nov 12, 2022 | 08:17 AM
LC911JEFF's Avatar
LC911JEFF
Just got back from another dealership that had a used 2021 vert for sale. It has the same gap as mine so it looks like that's normal. The flex explanation makes sense.. My OCD was kicking in I guess.On a side note, although I'm a bright color guy and love my infrared, the used lc I looked at was black with red and it looked amazing. Very stealthy. Car does look good in any color.
Old Nov 12, 2022 | 08:55 AM
Tom44's Avatar
Tom44
Glad you did not let the dealership touch your car. I can guarantee that they will f*** it up. If you have a problem, you have to go to a convertible top specialist. The dealer is the worst place for these uncommon issues. They will likely open a repair manual, take your top apart and put it back together worse than before.
How many convertibles does a lexus dealer deal with?: close to zero. I see that you are in CT? The tristate Lexus service depts are some of the most incompetent.
i am a long time Lexus owner of multiple models since 2001 and the service quality is much worse than in he past. I personally live with some rattles and creaks in my GSF because if they start trying to “fix it”, I will get it back in a worse condition.
my 2 cents.
Old Apr 10, 2023 | 05:57 AM
LC500JB's Avatar
LC500JB
9th Gear
Default Conv Top adjustment
Originally Posted by LC911JEFF
Picked up new 2022 lc 500 vert. Noticed a little bigger gap between windshield and roof on passenger side. Drivers side barely can stick pinky finger in. Passenger side finger fits easily. Wondering if it can be adjusted. I will call dealor tomorrow and keep updated.
Curious if you have an update. I have the same year conv with the same exact issue. Never been in rain or yet to hose wash, and wondering if it will leak or can be adjusted.
​​​​​​…….disregard……finally saw entire thread……all set.
Old Dec 21, 2023 | 12:38 PM
microsup's Avatar
microsup
Have same gap from passenger side. Been at Lexus dealership today doing oil change.(cpo) Mentioned about the gap, and was told that there is adjustment procedure and I need to make an appointment for that which takes couple of days. During service took a look at convertible seating in showroom, that one has exact same gap issue.
now thinking if I need to make that “adjustment” if they can’t replace oil without overfilling it. Now need to bring oil level to the recommended level.
Old Dec 21, 2023 | 03:15 PM
maraca's Avatar
maraca
Every LC vert I have seen has this gap on the passenger side. seam on the top is even. Must be "as designed."
Old Dec 22, 2023 | 06:59 AM
LC911JEFF's Avatar
LC911JEFF
Had the vert a year now and no problems at all at 4000 miles. The top is completely waterproof and no air noise. Guess they designed it that way with the slightly bigger gap on passenger side. On a side note, just put winter tires and rims on and was driving around top down with temps from mid 40s down to 35 degrees.With heated seats,steering wheel, and headrest was very comfortable.I like to experience top down driving year-round as long as roads are clear. Don't want my cars to sit in the garage for 3 months.
Old May 16, 2025 | 10:32 AM
23EMLC500's Avatar
23EMLC500
5th Gear
Default Lexus headquarters 6565 Headquarters Dr, Plano,TX 75024
My 23 same problem here I can see the sky & big gap on passenger, see the photo
Old May 16, 2025 | 01:33 PM
400Mman's Avatar
400Mman
@23EMLC500
Explanation from post# 12 in this thread.
This is normal according to Lexus and the dealership. A few vert owners asked my dealership shop buddy about this and he says Japan came back saying it’s engineering to allow some flexing and to alleviate stresses during twisting/flexing
Old May 16, 2025 | 08:15 PM
Bigfoot16's Avatar
Bigfoot16
the dealer will fix it under a service bullitin, its about a one hoir job.
Old May 17, 2025 | 05:38 AM
xwndycty's Avatar
xwndycty
Although my 2023 LC convertible doesn't have this problem (yet?), there was a March 7, 2024 Lexus Technical Service Bulletin issued about it (L-SB-0011-24 Gap Between Soft Top and A-Pillar on the Passenger Side). My experience with Lexus service so far (I've owned my car 2.5 years) has been excellent. I'm sure they will take care of it. Good luck!
Old Jun 6, 2025 | 06:32 AM
23EMLC500's Avatar
23EMLC500
5th Gear
Originally Posted by 400Mman
@23EMLC500
Lexus should check the wet test before ship to buyer. My problem is water LEAK through the GAP.
Old Jun 6, 2025 | 06:34 AM
23EMLC500's Avatar
23EMLC500
5th Gear
Old Jun 7, 2025 | 06:27 PM
tennman117's Avatar
tennman117
Just took my 23 in last week for it's 10k service.
Had them perform Lexus Technical Service Bulletin (L-SB-0011-24 Gap Between Soft Top and A-Pillar on the Passenger Side).
Didn't take over 30 minutes and no gap now.
Old Jun 7, 2025 | 09:28 PM
microsup's Avatar
microsup
Can you post a picture how it looks now. I have a little gap, not that bad as posted above, I just wonder if they fixed to the same distance as driver side.
Old Jun 8, 2025 | 01:42 PM
23EMLC500's Avatar
23EMLC500
5th Gear
Can you please send some picture
