Limited slip differential, 21-inch wheels?
Old Oct 21, 2020 | 03:28 PM
redhot47fl's Avatar
redhot47fl
Default Limited slip differential, 21-inch wheels?
My closest dealer finally has an LC ‘vert that is configured very attractively to me. And I am tempted. But I have two humbling questions.
I‘m an old guy and I don’t track, though I sometimes drive spiritedly. I’ve poked around and can’t find a clear answer on this:
1. What would be the attractions and disadvantages to me of the LSD? Basically, it’s a high-tech form of as-needed all-wheel drive?
2. From a comfort and ride perspective, should I be wary of the larger wheels and thinner tires?
Old Oct 21, 2020 | 04:49 PM
flowrider's Avatar
flowrider
Veteran: Air Force
My Opinion here -
1. The Torsen LSD on the LC is a very desirable option. When I bought my LC, it was a deal breaker. It has nothing to do with all wheel drive. The Limited Slip differential transfers power to a wheel with solid footing. A conventional or open differential sends power to the wheel with the least resistance.
https://en.wikipedia.org/wiki/Torsen
2. IMHO, the 21" wheels will not degrade comfort much over the 20s. However the RFT tires do have a rougher ride than standard tires. If you are unhappy with the 21s the dealer may, upon request, swap them out for the 20s. The 21" option is a desirable option. My LC came with 20s and I swapped them out for after-market 21s with non RFT tires. And just to add the tires on the 21" wheel are a bit more performance oriented than the tires on the 20" wheels.
Welcome to the forum. Us old guys need to stick together. I'm 81
Lou
Old Oct 21, 2020 | 04:52 PM
redhot47fl's Avatar
redhot47fl
Thank you, sir. That makes it easy for me - I want both.
I’ve been around here awhile, mostly lurking for educational purposes. I have a year-old BMW M850ix convertible, which is just fine, but I get bored easily.
Old Oct 22, 2020 | 08:30 PM
Tempest's Avatar
Tempest
+1 for @flowrider and his thoughts. My IS F had a Torsen LSD, my RC F had a TVD (torque vectoring differential), and my LC has a Torsen LSD. I don't think I would get a car without one.
IMHO, the OEM 21-inch wheels are some of the best looking wheels Lexus has ever designed. When my car was at stock ride height, the OEM 21's rode great; definitely an ample amount of sidewall for comfort. I've since upgraded to RSR springs and 22-inch wheels, so the ride is a bit rougher over bumps, but I prefer the look.
I'm a spiritual old guy of 41 that doesn't care about 0-60, quarter mile times, or blasting a car on the freeway, so I hear you. People are generally slowing down to check out the car anyways
zinn
Jun 1, 2013 11:17 PM
nsx042003
IS F (2008-2014)
41
May 17, 2013 04:47 PM
cv470
Mar 10, 2009 10:54 AM
JDMmuscle
May 9, 2007 04:54 PM
