Part Help Please
Old Jul 8, 2020 | 08:02 PM
woodranch's Avatar
woodranch
Hi, Thank you. Not sure I want to go thru all that work. A lot of labor to. Any thoughts about a wheel repair shop that works on chrome could possibly touch it up and at least make it look a little better. Only the lower portion was damaged? Thanks uchujin.
Old Jul 8, 2020 | 08:08 PM
uchujin's Avatar
uchujin
Sure - you could try that. But I'm thinking they'll want to re-paint the entire grille, and that labor cost could equal or exceed the cost of replacing the $300 grille piece. Get quotes both ways and see what works best! BTW - I can't find just the upper grille part and price, but I'm sure it's not more than $300. The lower grille is only $165 through partsmonster.com. See what your dealer can do for you. Good luck man!
Old Jul 8, 2020 | 08:38 PM
woodranch's Avatar
woodranch
Thanks and appreciate your help!
Old Jul 8, 2020 | 09:21 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Sorry if I misunderstood - But in Post #2, I asked for a pict. I have attached a pict of my emblem. Is the left arrow or the right arrow pointing to the blemish?
Lou
Old Jul 8, 2020 | 10:07 PM
woodranch's Avatar
woodranch
Hi, the blemish is on the right arrow front. Thanks and looking forward to your thoughts. Basically right on the front of where the right arrow is. The garage door scrapped that side pretty good.
Old Jul 9, 2020 | 09:58 AM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Hmm - And you say that's part of the grill? Sure looks like it's separate Sorry I mislead you!
Lou
Old Jul 9, 2020 | 11:06 AM
uchujin's Avatar
uchujin
Lou
Yes - it does look like a separate piece, but it may not be available as a separate part in the US if it's sonic-welded onto the grille. I found this out the hard way when I bought my lower grille - thinking I could swap my prox sensor assemblies. This isn't easy to do professionally unless one owns an (expensive) sonic welder. There are 2 lower grilles for the LC - one with the prox sensor mounts welded on, and one without those. This emblem surround may be the same story - welded on too. Sorry - I never looked at it closely when I had my bumper off. Any Lexus parts department should be able to tell you for sure, but from this grille assembly diagram, I'm gonna say one needs to buy the entire upper grille...
https://www.discountpartsmonster.com...bly-5310111020
Old Jul 9, 2020 | 11:42 AM
uchujin's Avatar
uchujin
To elaborate a little further... If you look at some Lexus parts - like the grille, there are lots of smaller parts sonic-welded in place. Those smaller parts all have valid Toyota part numbers stamped on them, but those numbers don't show up in the US dealer parts systems! They can't get those individual parts here. Because of the sonic-welding, one has to buy an entire assembly, I was told - in Japan, all those individual parts are available, but not outside of Japan. Not sure if this is accurate, but I wouldn't be surprised.
Old Jul 9, 2020 | 11:52 AM
flowrider's Avatar
flowrider
Veteran: Air Force
Well, just spoke to my parts guy - I even sent him the pict I posted above. And yes, I was wrong It is indeed part of the grill
Lou
Old Jul 9, 2020 | 12:22 PM
uchujin's Avatar
uchujin
Lou
Yeah, And I wouldn't be surprised if that part is sonic-welded to the grille with its own Toyota part number stamped on it. That doesn't surprise me so much but this does... Woodranch told me his Lexus dealer cannot get just the upper grille! He has to buy the entire grille assembly (lower grille, upper grille, emblem, chrome surround, lower grille insert)! This seems completely absurd, but it would explain why I couldn't find an upper grille part on any of the online sites. The lower grille on the other hand, is available as a separate part. Go figure...
Old Jul 9, 2020 | 03:08 PM
woodranch's Avatar
woodranch
Thank you all. A 1500 dollar mistake. I will bite the bullet and deal with it. Bottom line is Thank you for help and advice!
Old Dec 2, 2022 | 04:17 PM
lexuslcl's Avatar
lexuslcl
Bumping an old thread instead of starting a new one. I no longer have my LC, but my brother just purchased one and wants to replace the emblem. Has anyone done this with an aftermarket part? I have the OEM part that was provided in this thread by @danibear , but he wants a custom look.
Thanks!
Old Dec 2, 2022 | 06:09 PM
uchujin's Avatar
uchujin
Thanks!
The emblem has a radar sensor in it. Best you can probably do is wrap all or part of the OEM one. Others have done it. Not sure if or how that might affect the sensitivity of the sensor. Either way - might want to have the dealer recalibrate it. Probably not worth the effort IMO.
Old Dec 3, 2022 | 06:24 AM
your brother wants to replace the Lexus front logo that has the radar sensor in it with something that's not a Lexus logo? like what? and why? not judging, just wondering!
Old Dec 3, 2022 | 08:13 AM
Metal1's Avatar
Metal1
There is this:
https://carbon-addict.myshopify.com/...12496;ー
