Poor Interior Lighting Options
Old Jan 20, 2019 | 09:04 AM
Puertex's Avatar
Puertex
Default Poor Interior Lighting Options
I found a low cost option to help with poor interior lighting.
Energizer makes a line of battery powered Vision HD LED head lamps. Starting from 100 lumens to 400 lumens.
These come with a elastic band that I have installed on the visor.
I have the 315 lumen model and it lights up the whole interior when I turn it on.
It can be turned down some but you might consider a lower brightness model.
Old Jan 20, 2019 | 04:18 PM
uchujin's Avatar
uchujin
Just replace your visor bulbs with LEDs. It's a much cleaner and better solution. There are dozens of different choices out there in just about any brightness and color temperature. Here's a 10-pk on Amazon for 12 bucks. Each of these are 360LM:
Amazon Amazon
I put a much lower lumen version in my LC the first day I got it home. I forget the lumen number on mine, but they're plenty bright:
Old Jan 21, 2019 | 10:11 AM
SuperGT's Avatar
SuperGT
That's a cheap looking choice for such a premium car. Replacing the actual bulbs to high power LED plates like I did makes it 100% discrete and the light source area is the same as the originals.
Old Jan 21, 2019 | 06:12 PM
Puertex's Avatar
Puertex
Great ideas !
Thanks !
Old Jan 22, 2019 | 05:02 PM
Puertex's Avatar
Puertex
After evaluating the idea of higher powered vanity LED's, I think I will stick with my idea of using the Energizer LED option.
I don't like the idea of these lights on my face while with the Energizer, I can point it wherever I want or detach it for my convenience. Also they have two level brightness control.
Moreover, in my opinion, sometimes a high cost doesn't equate a better solution and the lights are tucked up with the visor when not in use.
I do realize that you have another solution and respect it but I just wanted to share with others in this forum that there are other options and initiate further conversation about the subject.
I respect other opinions and hope others respect mine.
Thanks, Puertex
bagwell
Lighting
Dec 27, 2017 09:25 PM
RA2425
Sep 22, 2016 03:02 PM
wakame
RX - 3rd Gen (2010-2015)
Feb 11, 2014 01:09 PM
Kyanite
Jun 21, 2012 07:55 PM
sc430uk
Jan 22, 2007 01:23 PM
