any reason NOT to PPF?
Full stealth PPF with ceramic coating, smoked headlights and window tint. Some discussion about the challenges of working with the canards.
Side skirts and a rear diffuser added and a peek at the trunk lid with the Inspiration wing removed.
LC content starts @2:40 with the final result @13:07
True, there is no way to avoid rock chips short of not driving the vehicle. Neither cautious driving, nor PPF is any sort of guarantee against rock chips during normal use.
That said, driving on slower roads with less traffic, as well as not following other vehicles closely can greatly diminish how many and how often your paint receives rock chips. If you commute on interstate highways at 70+ mph during high traffic periods, you'll get more rock chips than if you cruise at lower speeds on lonely country roads. I try to keep my classic car off the freeway and try to avoid following close. Also, it stays off the road during bad weather periods. Consequently, Its paint sees less rock chip damage than do my other vehicles. I drive my truck on gravel roads, dirt tracks, up snowy mountain canyons and on the interstate during high traffic. Its paint picks up more damage.
Over 20 dings in the PPF. Installer pulles it off and only ONE had made it through deep enough to cause a tiny chip in the paint. Had I not had PPF I wouldve needed a full respray of that front bumper. He put a new piece of PPF on and unless you knew precisely where to look you would never see the 1 tiny chip that had occurred.
I swear by good well installed PPF and will be doing it on my LC.
Check out that video on how the PPF is removed.
As mentioned previously on this thread, I've never considered doing a whole car, but doing the front, hood, and side mirrors seem beneficial. My daily driver ES came with partial PPF and I like it thus far.
It's a matter of preference.
If you are physically unable to wash / wax your car, PPF seems very beneficial.
Granted avoiding traffic and leaving a long follow distance can mitigate some but not all chances of things like this. I also took out a bird in my SLC recently and that marred my paint but PPF wouldve prevented 99% if not all of those scuffs. Also in TX if you leave a gap someone will just fill it.
IMO it is substantially more than just about being able to be less diligent about washing & waxing. The right PPF properly applied can prevent significant damage. A buddy had a tire tread come off a semi and glance off his front bumper & fender. It scraped the PPF bad but the paint underneath suffered no damage.
Granted avoiding traffic and leaving a long follow distance can mitigate some but not all chances of things like this but not all. I took out a bird in my SLC recently and that marred my paint but PPF wouldve prevented 99% if not all of those scuffs. Also in TX if you leave a gap someone will just fill it.
I also ate half a tire at 85mph. That one hurt the PPF quite a bit (as well as damaged my PCS sensor and trim around the emblem) but the clear coat under the PPF and the emblem (also PPF) are both completely unharmed.
https://youtu.be/mnj_EeaNvjI?si=8j1P5ywF5g3gEYlA
It's a matter of preference..
So at about 10:25 he discusses "why remove the PPF", and mentions 5-6-7 percent of value. Reference 5% = 125K. Was this customer's cost?
Owner of subject Porsche obviously had perfection in mind and an unlimited budget. As I watched kept wondering about cost to remove the PPF and little tricks the "master-remover" had in his tool belt. Anyway, correct me on how I interpreted the cost of this project. I am well aware the "restoration" at the shop (described as a studio) was far more extensive than the PPF removal alone; but also that issues to be addressed existed after the painstaking removal to move the needle toward perfection.
I don't think we have any indication of what this cost the customer, but given the value of the car and the likely prestige of the shop, I would not be surprised if the bill was $20k+ for this type of removal, painstaking paint correction, and re-PPF.
From video description:
This LC500 originally came in black. The customer had added carbon fiber parts to it. So, we changed the body to gunmetal using SPPF with Color's matte type. For the carbon fiber parts, we used SPPF's gloss type and painted them in a way that would highlight the carbon fiber weave. As a result, the finished product has a completely different look from the original! It has been reborn with a look that strongly emphasizes the custom elements. The original black is cool, but the gunmetal carbon fiber is even cooler.
It was so cool that my hands were shaking while taking pictures (lol). Moreover, since the painting was done with SPPF and SPPF with Color, it can be returned to the original black when reselling. I'll say it again because it's important. When reselling, it can be returned to the original black without damaging the original paint film. Yes, let's applaud again. Clap, clap, clap. However, there was one point to note during the application. Normally, if it were the gloss type of SPPF, it could be polished, but this body was the matte type. That's why it couldn't be polished. "So, we always take care of it."…
I've heard from one detailer/installer that the LC's sharp angles make it a less than ideal candidate for PPF. My hatred of rock chips, on the other hand, makes me want to do the hood/front fenders. My local PPF specialist recommends Kavaca PPF, in case that's relevant. Thoughts?
Yeah something like a C8 or lambo is WAY harder to do than an LC.
That said, unless your installer is removing the bumpers, trim pieces, etc you will have visible PPF edges in many places. The LC's panel gaps are so tight they are non existent. Can only wrap edges when you can get the PPF around them!
I can see my PPF edges on many panel edges and there are a few minor imperfections, but 99% perfect is good enough. Chasing the last 1% is all but impossible without removing panels and trim and I didnt want that done.
The imperfections in my PPF sure beat the damage my paint would take from pebbles, acidic bug guts, sap, and bird poo in the next 5-10 years before I have the PPF redone (10yr warranty but I think every 5-7 years is the sweet spot personally before it gets too banged up in TX).
I've installed and removed PPF and I don't understand why this guy is spraying the
top of the PPF while he is removing it instead of underneath where the adheasive
is. Also why he is working so hard with hot towels??? Use a steam machine and
be done with it.
be done with it.
