convertible power window problem
Old Apr 27, 2024 | 09:50 AM
davedudu's Avatar
davedudu
Default convertible power window problem
Both rear windows on my 24 convertible are closed and won't open. The passenger door and console window switches are not working. Both door windows work normally with the driver door window switches. I've performed the jam protection procedure in the manual to no avail. Any ideas? Does anyone know which fuse box holds the window fuses?
Old Apr 27, 2024 | 11:40 AM
Badhobz's Avatar
Badhobz
sounds like a problem with the top mechanism. Take it back to shop to get it looked it, it must be something misaligned somehow.
The rear 2 windows (those tiny glass) are only controlled by that switch next to the convertible top operation. That button lowers all windows/raises all windows.
You cannot control the rear windows from the driver side or passenger side.
Old Apr 27, 2024 | 12:31 PM
davedudu's Avatar
davedudu
Thanks for this. I live two hours from the dealership. I was hoping someone might know a "quick fix" for my problem.
Old Apr 27, 2024 | 02:30 PM
microsup's Avatar
microsup
When you operate your top, does it lower back windows? If so then it looks like it could be an operator problem. I hope you were trying yo open those windows with a switch at center console.
if when you open your top windows don’t move then it is a big problem. Take it to a dealer to fix.
Old Apr 27, 2024 | 02:56 PM
davedudu's Avatar
davedudu
I'm going to the dealer.
Old Apr 28, 2024 | 11:33 AM
LCIncline's Avatar
LCIncline
@microsup has the right question: Do the rear windows operate when putting the roof up/down? If so your windows are fine. I suspect that you accidentally hit the 'rear window child lock' button. Happened to me and it drove me mad till I figured it out. Check this first before driving 2h to the dealer. Why this button is needed for the convertible is beyond me though.
Old Apr 28, 2024 | 05:24 PM
Badhobz's Avatar
Badhobz
the child looks would only lock out the front windows (and only for the passenger I believe). The rear's are controlled by the top operation lever, or the "all window" button to the right of that top operation lever.
Old Apr 28, 2024 | 06:31 PM
microsup's Avatar
microsup
Ok, to make it clear I just tested how it works on mine.
when child lock ON then central switch which operates windows don’t work at all, but front windows still work fine from door switches. When child lock is OFF then central switch operates as it should.
So to make story short: if child lock is on then back windows will not move.
Old Apr 28, 2024 | 08:02 PM
LCIncline's Avatar
LCIncline
Yup. That's what I think happened to @davedudu . The lock is engaged and the rear windows don't operate. Happened to me as well.
Old Apr 29, 2024 | 10:27 AM
davedudu's Avatar
davedudu
This is it! I sure appreciate the help.
Old Apr 29, 2024 | 11:52 AM
Dukeaudio's Avatar
Dukeaudio
Relieved for the simple fix!
Old Apr 30, 2024 | 02:25 PM
davedudu's Avatar
davedudu
I really appreciate all the help I got here on the forum with my window problem. Having support like this is so important.
Old Jun 19, 2024 | 07:26 PM
scdroptop's Avatar
scdroptop
I just did this too, and you all saved me! Thank you! Ugh. I thought I had more issues on top of the clicking brake saga!
Old Jun 20, 2024 | 10:23 AM
LC500Dan's Avatar
LC500Dan
Did the same thing when I tore the entire console and dash apart to install the front camera harness. 3 days tearing it apart and 1 putting it back together and hoping I didn't mess anything up. Must have pushed the window disable button sometime during the process and panicked that I had done something bad. Couldn't figure why it worked the front from the door buttons but not the rear wing windows. Eventually got to it after I sat and thought about it for a while. What a relief.
Old Apr 18, 2025 | 02:54 PM
tjh1's Avatar
tjh1
Hey thanks!
New owner here. Took it for a ride to the dealership about 15 miles and across a bridge away today. Put the top down and all four windows ended up down too. But, when I parked it and put the top up, the back windows would not come back up. I was worried that I had a problem.
Directed here by a search and, walla, I forgot about that middle window control. Walked out in the garage, got it into run mode without starting, pulled the center window switch up and all was back to normal. I was relieved to say the least. I owe you a beer!
