Wheel alignment?
Old Feb 18, 2024 | 11:30 PM
jamster330's Avatar
jamster330
Default Wheel alignment?
The last time I got my wheel alignment done was about 15-20k miles ago. Took it to the dealership for a 60k mile service and they did no alignment on the vehicle. Is it worth getting done? I don't really see an issue with the steering or anything but was wondering what the recommendation is for these cars?
Old Feb 18, 2024 | 11:58 PM
You should never need an alignment unless you bend something, or you've replaced worn out components. Canary in the coal mine is uneven tire wear if you don't have you likely don't need an alignment. It is normal for the outer part of the front tires to wear down a bit faster. Or if you drive like you stole it all the time but that's a different conversation.
Old Feb 19, 2024 | 12:29 PM
flowrider's Avatar
flowrider
Veteran: Air Force
Didn't you just ask the same question a couple days ago
https://www.clublexus.com/forums/lc-...e-vehicle.html
maximakid
Mar 11, 2013 04:48 PM
Och
Apr 2, 2012 02:04 AM
ADVocate
GX - 1st Gen (2003-2009)
13
Apr 21, 2008 06:32 AM
STONER
May 19, 2006 04:41 AM
