MY '24 Wheel Specs
Old Dec 7, 2023 | 11:48 AM
Dukeaudio's Avatar
Dukeaudio
Default MY '24 Wheel Specs
Previous yr specs:
Hub Bore- 60.1
PCS- 5x120
Thread Size- M14x1.5
I've never owned a car that used lug bolts so pls don't flame me, I've searched CL and found a few discussions re '24 wheel specs but nothing definitive. Considering new wheels, and no one i've inquired with has '24 specs. Some have even asked me to measure (i would have but can't find my calipers). Question, is the only thing thats changed for MY'24 wheel specs is going from lug nuts to bolts? TIA🤙🏽
Old Dec 8, 2023 | 12:47 PM
JCtx's Avatar
JCtx
I didn't know the '24 changed to lug bolts. I don't like them either, but my ex-Porsche had them. I bought 2 long 'studs' to insert them when removing a wheel, to avoid damaging the caliper paint... which is very easy to do. You still have to be careful with lug nuts, but at least you can remove all nuts without the wheel falling off, then carefully slip it out. Wonder why the change. Nuts are much better, since they only have an axial load, and not a radial one too. Therefore, I bet the torque is quite a bit higher as well. The Porsche required 118 ft/lbs; wonder how much for the much heavier LC now.
Old Dec 9, 2023 | 01:59 AM
Dukeaudio's Avatar
Dukeaudio
103.3 ft/lb per my owner's manual. Calling my svc agent re purchasing necessary tools (jack, guide pin, wheel bolt socket/wrench, and jack handle). Why not incl is frustrating.
Mistamoo
RX - 5th Gen (2023-present)
26
Jan 11, 2024 04:44 AM
Lextazy
GX - 1st Gen (2003-2009)
18
Sep 30, 2019 01:19 PM
Benoit
Wheels, Tires & Brakes Forum
Apr 25, 2019 01:49 AM
chnk
Aug 26, 2010 10:16 AM
ChuH
Jan 17, 2003 04:44 AM
