DIY: 2011+ MY LED Headlight Installation ("How To")
Old Feb 5, 2013 | 04:15 PM
  #136
speedstar's Avatar
speedstar
2012 LED headlights (not from Sewell) and it was a success.
-2006 IS350
- move the green wire next to the open spot where the white/black wire is
- tap into the red wire and white/black wire using T-taps to connect the 2.
do not cut the red wire and wire it into the white/black
This way worked for me, not sure for others..
Old Feb 5, 2013 | 05:15 PM
  #137
Davidcv4's Avatar
Davidcv4
Mind....blown
Old Feb 10, 2013 | 12:39 PM
  #138
MadCleaner's Avatar
MadCleaner
Would I lose headlight turning feature if I upgrade to these?
Old Feb 20, 2013 | 04:27 PM
  #139
ms2619's Avatar
ms2619
Originally Posted by Vroomin350
You will have to rewire if you want 100% brightness.
100% all the time? or is there a way to wire them up 100% during the day and once low beam turns on they go down to 50%? I can't find the relay flasher on sewell and the wiring cap for the bottom for the LED....someone please post some links so I can order, ima DIY noob.
Old Feb 20, 2013 | 05:15 PM
  #140
CalitriSC's Avatar
CalitriSC
Yuo no IS after 2010 has AFS (turning projectors) which I could care less about. They barely made any difference anyway lol.
Old Feb 20, 2013 | 06:35 PM
  #141
Silec's Avatar
Silec
relay
http://is.sewellparts.com/accessorie...2013/5311.html
led harness with cap
http://is.sewellparts.com/accessorie...2013/5597.html
cap for high beam
http://is.sewellparts.com/accessorie...2013/5598.html
Old Feb 20, 2013 | 08:55 PM
  #142
ms2619's Avatar
ms2619
Thank you! 2013 will work for the 2011's right? I really appreciate it Ima order everything in the morning! As far as the wiring goes anyone got input?
Old Feb 20, 2013 | 09:21 PM
  #143
CalitriSC's Avatar
CalitriSC
I put 2013 lights into my 08 ISF last week. For the wiring you do not need to do any splicing, just moving the wires to different locations. Takes like 5 minutes and mine work perfect.
Old Feb 20, 2013 | 09:31 PM
  #144
Lestrade's Avatar
Lestrade
Wow, that's a very thorough DIY. Good work.
Old Mar 23, 2013 | 08:29 AM
  #145
isfnext's Avatar
isfnext
Hi just want to know i have been reading a lot and still unsure. I have a 2006 is350 with oem hid afs. As far as i know i ll be loosing the afs right? Also i ll order the strip version from sewell is there something needed or swapping the parts from my old headlights will be fine? The relay, led harness with cap and cap for high beam that some are talking about are they included and needed? Also are you running all time led on at 100%? Thanks a lot man i m just about to order this upgrade... wanna make sure i have everything needed.
Old Mar 23, 2013 | 01:15 PM
  #146
Kitty2IS's Avatar
Kitty2IS
how much did everyone pay for a set of these..? i think the price on sewell just went up again ..
Old Mar 23, 2013 | 01:30 PM
  #147
CalitriSC's Avatar
CalitriSC
$900 shipped for mine barely used. Still look brand new.
Old Mar 23, 2013 | 01:46 PM
  #148
Kitty2IS's Avatar
Kitty2IS
i take it that's a rare exception ?
Old Mar 26, 2013 | 10:53 PM
  #149
SpoolinTeg's Avatar
SpoolinTeg
Just used this DIY to install mine. Thank you!
On another note, **** that relay! I'm a bigger dude, so I couldn't simply lay in the footwell to install it. I had to hang out the dang doorway and remove and install everything with one hand, while not being able to ACTUALLY see the relay at all.
I couldn't get the relay to snap back into the hole, so I just zip tied it up there for now.
Thanks again!
Old Mar 27, 2013 | 05:11 PM
  #150
aspeckt's Avatar
aspeckt
Just installed the 2012MY LED Headlights Loaded from Sewell and these are my questions:
1.) DRLs -- If i get it disabled by the dealer will it cause me to lose my high beam function also?
2.) LEDs -- are they at 100% after install with no modifications? Is there a downside to this?
3.) Bubbling defect -- Can someone explain this to me? I've looked everywhere and all I know is its bad. Does it have something to do with the LED running at 100% and the Low beam on?
4.) What color temp matches best with the LED strip for Low Beam/Fog combination
