How to DRY your car?????????????
Old Jul 19, 2010 | 10:23 PM
danhtran's Avatar
danhtran
Default How to DRY your car?????????????
**** just happen to me on last Saturday
So i went to work and park the car outside....... I remember I pull all the window up and lock the car....... After work i came to the car all the window were half way down and it was raining as hell.... The SEAT and FLOOR was supper WET.... How am i gonna dry my car? and its still raining from that day till now...... The car is really moisture
Can u guy gime some opinion about this?
BTW the moon-roof was still close.... lucky tho
Old Jul 19, 2010 | 10:32 PM
pli's Avatar
pli
throw rice on your carpet for a day or two and vaccuum it afterwards? lol. just kidding (but hey, it'd work)
Old Jul 19, 2010 | 10:46 PM
Jetfire's Avatar
Jetfire
Royale with cheese
was your remote in your pocket? you probably pressed the unlock button and it rolled down the windows.
first get a wet/dry vac and vac up as much as possible, then grab as much silica packets as you can. those soak up a lot of moisture.
if you have a garage get some fans going.
Old Jul 19, 2010 | 11:45 PM
tigabalm's Avatar
tigabalm
Whatever you do to dry it out make sure you do it as fast as possible as well. Otherwise mold will start to set in and that just gets real ugly real fast.
Old Jul 20, 2010 | 01:11 AM
sw2oboi's Avatar
sw2oboi
obviously whip down the plastic and leather as much as you can, remove seats and let them dry in the sun. i know that sounds kinda crazy,but id wanna get those as dry as possible quickly before mold grows. last thing with the carpets, it would help if u get a wet dry vac, not bunch of towels.
you were lucky that the sunroof didnt open up. if the button on your keyfob were held a bit longer it prob woulda crack open the sunroof. i hope everything gets dried nicely.
Old Jul 20, 2010 | 07:00 AM
iSuxeL's Avatar
iSuxeL
First things first, keep your windows rolled down and use as many dry towels as possible to soak up the water. Most of that water is just going to evaporate.
Old Jul 20, 2010 | 08:28 AM
Karlson's Avatar
Karlson
Yeah you definately want to get pools of water out first and then use an absorbant, like a chamois or lots of paper towels to soak up any remainding water. The rest should be air dryed with your windows rolled down. You could also go to a store and buy a canister of silica gel/ air moisture absorbers and put that in your car, they're mainly used for closets and rooms but this would work in your car as well.
Old Jul 20, 2010 | 08:36 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Here is a similar thread I replied to in the past I recalled
https://www.clublexus.com/forums/gs-...86-wet-gs.html
Originally Posted by DaveGS4
Wife left windows down in a storm once in my LS430 so I have some experience in this area...
Get towels out on the seats to absorb as much as you can.
Use a wet/dry vaccum to pull as much water out of the carpet and seats as you can (be careful that the vacuum isn't super-powerful one when using on leather so that it pulls it in - can't recall if the GS has perforated seats which will help it work well).
Not sure if this is an option for you to pull the car in a garage (or even outside) with the doors open and let air circulate through it. At one point I had two large Patton house fans blowing through front and back and two small oscillating fans inside. I did this for a full day.
We also got some small buckets of moisture absorbing material (usually used in damp basements) and left them in the floorboards - not on the leather! - overnight for about a week to help pull additional moisture out of the car. I'll try to find a link to them - didn't know they existed before this incident. Edit - here is the stuff... we used two little buckets I'd guess 40 oz size found at Ace Hardware or Home Depot
http://www.damprid.com/
After the leather was as dry to the touch as I could get it with towels & wet/dry vacuum I used Meguiar's leather conditioner on it pretty heavily, then repeated about a week later.
Car came out fine without any issues.
I've recently seen that damprid stuff in bulk at Costco at a pretty cheap price.
Old Jul 20, 2010 | 08:40 AM
Robs IS250's Avatar
Robs IS250
They have the Damprid at Walmart/Target, it works miracles! Good luck buddy, everyone has posted good info so far so go with that!
Old Jul 20, 2010 | 11:42 AM
Jetfire's Avatar
Jetfire
Royale with cheese
i got the jdm version of damprid for $2. Daiso for those who know it. works pretty well.
Old Jul 20, 2010 | 11:52 AM
shadowman's Avatar
shadowman
Sorry to hear about the car...
I would also be worried about the electrical components from shorting out or corrosion build up.
Anyway, like what others said... use a shop vac to suck up any water on the carpets. Once you get the water out... you may want to use a hair dryer on the carpets and trimmings to help dry off some water that might have gotten on electrical components.
Old Jul 20, 2010 | 11:58 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
use a dehumidifier....
Old Jul 20, 2010 | 11:59 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
Default sorry OT
sorry off topic...
the Daiso by Abrdeen Center? That's a huge one!
Old Jul 20, 2010 | 01:30 PM
tenaciousF's Avatar
tenaciousF
https://www.shamwow.com/default.aspx?did=&refcode=1002
problem solved.
Old Jul 20, 2010 | 02:28 PM
BradInPhx's Avatar
BradInPhx
Go rent a carpet cleaner and use that to suck out the water from the floor if there is a lot. Or borrow someones. Hell go to walmart, buy one and then return it tomorrow.
