Need help with finding a part number
Old Nov 9, 2021 | 08:21 PM
predacon47's Avatar
predacon47
Default Need help with finding a part number
Hello CL Fam,
So I messaged up yet again. When I was installing my AOS, I yanked on a line and cracked it in half. Now I’m in need of help finding a part number so I can replace it. Long story short, I’ve been having the dreaded P0101 code even after replacing the MAF with a oem denso. All my vacuum lines from the RR intake seems to be ok and all clamps are tight. I took off the rr cf elbow and put my hps thinking it would help. This is the only part I know that’s messed up. I tried to glue it back together but I’m pretty sure it’s still leaking air.
I’ve circled the item I’m referencing in the attached pics. Thanks in advance!
Old Nov 9, 2021 | 08:40 PM
93MSB's Avatar
93MSB
2008 Lexus IS F Hose, fuel vapor feed. Engine - 2382938050 - Genuine Lexus Part
in the mean time, I've had decent luck wrapping broken hoses with electrical tape until a replacement is sourced
Old Nov 9, 2021 | 10:02 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
That one turns to glass at the manifold end. If you ever take it off, be sure to have a new one on hand because it will for sure break on you.
GaryC17
Nov 1, 2025 03:39 PM
dhuyzee281
Sep 3, 2021 06:10 AM
natoo
May 20, 2021 12:07 PM
xJimy23x
Sep 1, 2017 11:42 PM
