2011 ISF vs 2012+ Changes
Hi Everyone,
Just picked up a 2011 lexus isf. Just curious about the suspension changes and wondering if the 2011 vs 2012+ is interchangeable? Based on the changes to the 2012+ its only the shocks/springs that change so i assume the rest of the geometry is the same so the parts on my 2011 could be updated to the 2012+ with the change of shocks/springs? Were there any other changes in the 2011+ like bushings for the front (common issue with inner tires wear in the fronts) etc? Thank you!
I think the only difference to suspension are the shocks/struts (maybe springs), and they should bolt right up. No changes to bushings that I am aware of - all F's suffer with the inner tire wear issue. Aftermarket LCA bushings and close to zero toe alignment seem to solve the issue.
