So what's the correct spark plug gap?
Old Apr 1, 2020 | 05:41 PM
Joe Z's Avatar
Joe Z
Wink
Originally Posted by flowrider
^^^^The TT plugs have been discussed in the past. Both in the 2IS and ISF forums. I have eight of 'em sitting in the garage.
Asroll down to post #48 and continue.
https://www.clublexus.com/forums/is-...008-isf-4.html
https://www.clublexus.com/forums/per...ark-plugs.html
Lou
I missed you too Lou... I used air quotes for "Go Faster"
Old Apr 1, 2020 | 06:34 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^^Aw Joe - It's GREAT to have you back - FULL TIME
Lou
Old Apr 1, 2020 | 07:56 PM
Joe Z's Avatar
Joe Z
Lou
Joe Z
Old Apr 1, 2020 | 10:11 PM
MileHIFcar's Avatar
MileHIFcar
Speaking of that Joe, where did you disappear to for a couple years it seemed like?
Old Apr 1, 2020 | 10:17 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
He got busy with life. Happens to the best of us from time to time.
Old Apr 19, 2020 | 07:34 PM
AlOtaBblGm's Avatar
AlOtaBblGm
Thanks JoeZ. I have an inquiry in to my online manual supplier as to where exactly they got their spec. I will say this, the engine is definitely a little peppier. But 1.1mm it is. Done. Settled. Finis. Engine even sounds a little different. I may pull them and regap to 1.1 just to make it right. Depends how bored I get.
Old May 3, 2020 | 07:50 AM
Joe Z's Avatar
Joe Z
Question
Since we have all the right subject matter experts in this thread...
I was curious to understand how the spark plugs found in the RC F / GS F / LC 500, may or may not work correctly with our IS F..?? 2UR-GSE platform
19100P SPARK PLUG
Part # 90919-01279 / FK20HBR-J8
Gap = 0.031 in. / 0.8 mm
The IGNITION COIL ASSY, part # 90919-02260 are identical in all these applications.
Below is some of the Yamaha Motor Tecnical Review data during development of updated 2UR-GSE.
Joe Z
Old May 3, 2020 | 05:09 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Higher compression engine, smaller plug gap. That's pretty normal.
Old May 6, 2020 | 01:10 PM
AlOtaBblGm's Avatar
AlOtaBblGm
Yep. Might be a colder plug too. Not sure.
Old May 6, 2020 | 02:56 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
No. They're both 20's. The heat range is the number right after the size code.
https://www.denso.com/global/en/prod...ies/plug/type/
Old Mar 13, 2023 | 01:34 PM
txjeff's Avatar
txjeff
Originally Posted by sickpuppy
The Denso FK20HBR11 come pre-gapped. The factory gap is set to Gap: .043" (1.1mm). In this day and age, I would not mess with a pre gapped plug.
Lou
I just bought those plugs and the were pregapped to .032". Just sayin.
Old Mar 14, 2023 | 12:33 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
If you bought FK20HBR11 plugs and they measured 0.032", they were damaged or counterfeit. The 11 at the end means 1.1mm gap from the factory.
Old Apr 15, 2024 | 02:43 PM
Mesh704's Avatar
Mesh704
Hello guys, this is very good thread to discuss.
So I have GS-F and I change pistons compression from 12.3 to 10.0 forged to be prepared for the SC roots kit.
But for now I will use and tune the car for NA
So my question is, dropping the compression from 12.3 to 10.0
What gap should I set mine at ?
I will use heat range 6 from NGK
But what gap do you recommend ?
Stock GS-F gap .031 ( 12.3 compression )
Stock IS-F gap .038 ( 11.8 compression )
So my engine now is at 10.0 compression
All opinions are welcome and thanks for the support
Old Apr 15, 2024 | 03:10 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Without boost, the factory plugs will work fine. After boost, especially starting at 10:1, you'll likely need to change heat range and gap to suit the new conditions.
Old Apr 15, 2024 | 03:24 PM
Mesh704's Avatar
Mesh704
So you recommend to use .031 on 10.0:1 compression ?
Also iridium or ruthenium hx ?
