Isf shifting problem
Old Dec 28, 2019 | 08:49 AM
Gsxrlover's Avatar
Gsxrlover
Default Isf shifting problem
So yesterday night I noticed my car jerked hard when shift from 2nd to 3rd in manual mode i replicated this a few times just to assure myself it wasn't a fluke also let off the gas befor shifting, then held the gas while shifting up and still a hard jerk of the car. Shifting Down it shifts perfect. also a slight jerk in auto mode but not as bad. in town going slow the car would skip from 2nd right to 4th if I was taking a Corner while breaking, going really slow like driving through a parking lot slow. Before hand i always let the car warm up for 30 to 45 mins before driving and always the the first 3 shifts would seem to slip in the morning. But after that it was smooth shifting. If I shifted between gears while parked it's almost like the solenoids would build pressure and it wouldnt have that slip/ jerking motion on first drive. if I left the house in manual mode it shifted perfect. Does any one have any insight to what could be happening?
Old Dec 28, 2019 | 11:56 AM
ISF4life's Avatar
ISF4life
what year and how many miles ? there are a few isf that has those problems happened 100k + miles. Search is your friend.
Old Dec 28, 2019 | 12:19 PM
Gsxrlover's Avatar
Gsxrlover
2008 with 117000 miles just had transmission fluid exchange 4k miles ago
Old Dec 28, 2019 | 12:56 PM
LexusfanVA's Avatar
LexusfanVA
Idling a car for 30-40 minutes won’t really warm up the transmission. It’s winter and even with 40-50 degrees I can leave for work in the AM and not warm up the transmission driving 20 minutes to work. I think you may need more driving time before you can see if it’s an issue or not.
Old Dec 28, 2019 | 02:46 PM
2013FSport's Avatar
2013FSport
How well do you know the shop? If they left it low by not checking / setting the level properly it may account for some of the strangeness. That aside, I would advise you to start it and drive it as 30" of idle is harmful to the engine, does no good for the charging system which speaking of; if the voltage is unstable from a weak battery this too could induce odd behavior.
Old Dec 29, 2019 | 03:33 PM
BlckGhst's Avatar
BlckGhst
Definitely confirm the level is correct first
JPcoISF
IS F (2008-2014)
22
Apr 16, 2016 12:19 PM
driven5373
IS F (2008-2014)
21
Aug 13, 2013 07:16 AM
JonP
IS F (2008-2014)
38
Oct 12, 2012 11:19 PM
kenysl
IS F (2008-2014)
15
Apr 19, 2011 03:30 AM
IS350atWOT
IS F (2008-2014)
12
Apr 1, 2010 02:16 PM
