OEM rims square setup question
Old Apr 28, 2018 | 11:35 AM
lexicon72's Avatar
lexicon72
Default OEM rims square setup question
About to get a 2nd set of 2008 OEM rims and was curious.
Could I use the 4 fronts for a square winter setup and the 4 rears as a square summer setup?
Old Apr 29, 2018 | 05:35 PM
tas02's Avatar
tas02
I haven't tried this, but see no reason why it's not reasonable with ARP wheel studs and 10 mm spacers up front for the summer setup.
Old Apr 29, 2018 | 08:02 PM
Jz39's Avatar
Jz39
I test fit the 11 rear wheels on the front and you would just need a 10mm spacer as mentioned. You might even get away with a 5mm spacer, but I couldn’t tell for sure, you’d need to test fit.
pvong713
Jul 31, 2013 09:26 AM
try2fndmrk
Apr 12, 2011 10:03 PM
mikeho
Jul 15, 2009 10:56 PM
phoenixm3
Suspension and Brakes
Dec 3, 2003 06:15 AM
