ProForce Hub bearing review.
To everyone who needs hub bearings I am taking a bullet for all of ya and got eBay brand for my isf. Why one might ask? Well because it was $100 (and not $240 -Timken) which should already be good for a mother hub frickin bearing on a Toyota!! Anyways it carries a timken part number ok? And it is identical to OEM one. Pictures below. So u be the judge. Plus it has Demso ABS sensor just like OEM. after install it rides just like OEM haven't noticed any horsepower or handling increase so yea...
Curious, what were the indications that the OEM hubs were going bad, and how many miles on them?
Thx for sharing with everyone though
Awesome! Had a similar experience in the past on rock auto. They were selling some injectors under a private label, so i took a leap of faith. Come to find out when i got them, it was the exact ones as OEM (part # and everything). In short, there is a lot of money to be saved if you look hard enough.
Tech Info Resource
What did you do with the old hubs?
Tech Info Resource
Tech Info Resource
It all depends on how the car is used. Tracking will wear out wheel bearings much faster. Running stance offsets will wear out wheel bearings much faster. Hitting curbs can ruin a wheel bearing in a single blow. It's not difficult to test them, but if you have an event sufficient to require a wheel repair, odds are good you'll be replacing the wheel bearings fairly soon.
If you have ever owned a boat you will know the difference in cheap bearings and Timken's. You don't even get a season out of cheap wheel bearing salt water eats them, whereas good bearing last 2/3 years with the same maintenance.
yes timken is the only one from ROCKAUTO that is confirmed to work. There is a member here who said he bought them all only to find out none for besides timken (that being the most expensive option)
used eBay off branded on my BMW for a while, still working good few years later. That account seem to be in good standing and offers same warranty as timken - 1 year. I just tired of buying brand not product. I often notice even branded things fail often, Sony, Phillips (had headache with both today) and others while some walmart cheap things are still working stong.
