Last Sunday ISF and CTR
So did my third track day last sunday. Getting better, but i was amaze how good was the new Civic Type R on the corners. On the straight i pull away but, once we got back to the technical part of the circuit, he will be on my back bumper. I have the stock suspension and im all over the place while he is able to keep a better race line taking on teh corners. Well today i placed an orders on FIGS for a set of BC Racing Coilovers, hopefully iill get better balance turning.
Nice, although not sure the BC’s will help much on the twisty bits? Got these myself at the moment, good all rounder, but not firm enough for proper track work in my opinion. Don’t get me wrong, good value for money.
Enjoy the track time though, looks like a lot of fun!
Im running on toyo’s r888 235 35 19 on the 4 corners. I know i need wider ones, but in 19 they jump to 265 which will rub in the front. In plans, switch to 18” wheels eith 255 all around.
The new Civic Type Rs are pretty solid performers though. Seems like you had fun running with it on the track!
V.
235's on the rear....?!?!?!?!������. What year is your F?! You need 255-275 on the rear, minimum. 235 up front will get you by, but not at the rear where the power is going, lol.
The new Civic Type Rs are pretty performers though. Seems like you had fun running with it on the track!
V.
V.
When you are on the race track, weight is everything. That Honda is quite lite. If the F was anywhere near it, weight wise, nothing would beat it.
235's on the rear are causing much of your issues. If I tracked it, I'd go 275 30 19, which most suggest as the correct size.
Tech Info Resource
I doubt it's the car. More than likely it's the driver if it was your first day at the track with your F.
Were you using the stability controls or did you turn them off? That made the biggest difference to me when I was having issues placing the car on the track.
And those skinny tires - why? This is a 3700+ lb car. It needs a whole lot of rubber under it. If they were 235 slicks, that might work, but street tires or even DOT legal R compounds will struggle with a car this heavy.
Third track day, My rationale on the 235 tyres was that being the R888 a semi slick with a 100 threadwear, it was goint to be more sticky even at 235 on the rear. I got these tyres for a great deal almost new (a guy bought them for his CLA45 and only went once to the track), so i decided to give it I try. I guess it didn't work out, so more contact area sometimes is better than a low threadwear. Now im considering going 18" (more choices of sizes) maybe with a 255/40 square setup still on 888´s or other R compound tire.
Here is a short video on that session where there was a crazy dude on "SUV" Grand Cherokee SRT and behind me, the civic. Be aware that some "Track Days" protocols are not 100% homologated in Panamá, although i let them past me
Tech Info Resource
You would be in a better place with good street tires in 275/30 and 255/35. The 888's aren't bad tires, but they'r DOT legal tires so the amount of grip they have is still pretty limited compared to real slicks. Speaking of which, that standing water on the course is a good reason to be shy of running full slicks.
And yes after watching your video, most of this is really driving. If you have the opportunity to get an instructor to help you better dissect the track and get some clean lines you'd be amazed at how quickly you can improve. Going alone more often than not just reinforces bad habits and you progress very, very slowly compared to having second set of eyes guiding you around the course so you can focus more on car control and less on when to be doing exactly what.
IronNam (01-22-18)
Enjoyed watching the video! Thanks for posting!
V.
V.
On the other hand, whats you opinion on square setup, based on your recommendation, it doesn't seems something you are in favor of. ?
