Help with RR Racing Air and Oil separator
#31
#34
Tech Info Resource
Way overkill. There's zero pressure in this setup, so even a stainless braided rubber hose would be way overkill. I like this setup a lot. Those OEM style clamps are amazingly reliable for what they are as long as they are properly sized.
Rickna (06-28-19)
#35
just mainly for aesthetics. the samco id try and run black for more of an low key look too.
#36
Tech Info Resource
There is no pressure on this hose, vacuum is a much bigger concern than pressure, but truthfully if the hose collapsed from low pressure, it wouldn't be bad at all. The engine was designed with a full return oil scavenging system (you have to remove it to fix the valley plate leak). It's designed to remove the OIL (not the water vapor or organic acid blowby) from the crankcase, and return it to the crankcase. Which is why I have consistently and persistently asked those with the AOS to send the contents of their AOS for analysis and get a clear picture of the composition of what the AOS is collecting. So far, no one has reported back what the AOS actually collects. Since I have not seen a before and after KCLV, or the results of an analysis, I have not and will not install any catch can of any type. The PCV system, as designed by Lexus, seems to work. Did anyone see a catch can on the Lexus CCS-R? I didn't. If you did, please post a photo and point it out. Maybe I'll reconsider the whole idea, but at this point what I see is a device working just like a coalescent filter. Sudden volume increase causes water and organic acids to fall out of vapor (see Charle's Law and Boyle's Law) and collect in the catch can. Does it make a real difference? You guys logging KCLV should be able to say - did the AOS change your KCLV?
Keep in mind, I was Chief of Operations for a gas analysis laboratory using 6 tons of liquid nitrogen a week to cryogenically distill gases of interest from whole air. I know a little bit about the gas laws and their practical applications, so if you have a response, be sure you know your science first.
#37
would that help?
#38
Tech Info Resource
If your asking to send the contents to say Blackstone, id be happy to do it. My F is due for its oil in a bit. itll be the last time i run it without the AOS. I already have my Blackstone container waiting for an analysis. So figure I can install it once i get the upgrades installed and record how many miles it was on for.
would that help?
would that help?
#39
I wouldn't know where to start. I can email BS once my initial test comes in and i do a full oil change interval with the AOS. maybe they can give me a proper lead.
#40
I had an issue with my RR Racing AOS leaking and throwing codes. Took it off and mentioned to RR Racing that it was leaking and throwing codes, they just mentioned I had probably not installed it correctly (never put it back on my car). Anyone have a photo of the rubber seal where the tank screws onto the top? The seal on mine looks weird. Ill see if I can post up a photo here.
MLRSTJ (12-18-19)
#45
@ ALexusF, Not sure if it melted, but it's definitely deformed.
