Help with RR Racing Air and Oil separator
Old 07-18-17, 10:20 AM
Justin727
Justin727's Avatar
I installed as per directions. BUT I do not think the canister is flow specific. I looked over my piece a great deal before installation and did not notice any inlet/outlet markings which tells me it shouldn't matter. I will double check this next time I'm in the garage near the ISF.
Just browsing their site and seeing V1 pictures it also appears to be non flow specific.
I think you all should be fine.
ISFTOMMY (07-18-17)
Old 07-18-17, 11:13 AM
PDP180180
PDP180180's Avatar
Different issue, but wanted to caution anyone with the later thumb screws for their canisters. I popped the hood at the weekend whenI was cleaning the car, and one of them has worked itself loose, and disappeared!
Hoping it might be in the undertray, but just wanted to let folks know it's an issue.
Noticed the screws on my tuned intake also seem to work themselves loose?!
Getting in the habit of checking them more often nowadays.
Old 07-18-17, 11:29 AM
3nergiz3d
3nergiz3d's Avatar
I'm not sure if you have their canister which has an arrow marked. This arrow marking is raised and I had to file mine down so it became flush. I haven't had any issues after filing the arrow down. This was for the earlier batches of canisters with the updated thumb screws. Ignore this, if you have the latest version.
Old 07-19-17, 07:54 AM
Fivepoint0
Fivepoint0's Avatar
Just took my AOS apart (v1) and has an arrow on the top.
Old 07-19-17, 12:35 PM
Justin727
Justin727's Avatar
Then there you have it!
my V2 was ground down from RR so there wasn't an arrow on it at all. I did look last night.
Old 07-19-17, 11:15 PM
PDP180180
PDP180180's Avatar
Thanks.
I'll check this out. Mine is also the early version, just decided I liked the thumb style screws as opposed to the hex type it originally came with.
Appreciate the info though mate.
Old 08-12-17, 05:56 AM
Defratos
Defratos's Avatar
So looking at mine a few weeks back I have mine installed like in pic number 2 but have always had leaks as in the picture below.
Do you think RR could send me a replacement set of tubes for this? as I believe mine is installed incorrectly:
Old 08-12-17, 11:40 AM
Fivepoint0
Fivepoint0's Avatar
Something looks off from the pcv hose, do you have the adapter on the hose ? Cant tell from the pictures with the valve cover on. From the pcv hose should have the adapter to the aos blue hose . The clamp should be on that hose not the blue .
Old 08-13-17, 03:08 AM
isfvss
isfvss's Avatar
Come on RR get off the golf course and chime in.
Old 08-13-17, 03:35 AM
Scott610
Scott610's Avatar
Default Cel ?
Had and old one from rr racing and was leaking air at the two screws and cel was on and vsc light was also on took it to a shop and they did a smoke test to see where leak was . The shop I got it done at used teflon tape to prevent it from leaking but here and there it would leak and cel would come on . One day my brother had my car and that day cel was on and he totaled the car cuz there wasn't no vsc when cel is on . Not putting a blame on rr racing because it was also raining a wet that night but if vsc was on it would've probaly help him from slippin and losing control . But now I have the newer version in my new isf and works fine . I would do a smoke test to see where leak coming from .
Old 08-13-17, 03:38 AM
Scott610
Scott610's Avatar
My old one on my 08
Old 08-13-17, 07:53 AM
Fivepoint0
Fivepoint0's Avatar
Get the new reducer/adapter if it's leaking from the pcv hose
Old 06-12-19, 01:34 AM
HurtadoISF
HurtadoISF's Avatar
Does anyone happen to know what codes we would see if the AOS was leaking? I keep getting codes ever since installing (P117B/P050B/P0101) also my MPG has dropped by 5mpg. I’m thinking my PVC line that goes into the engine is possibly leaking but it’s a right space down there and I can’t reach it to check or better secure it.
Old 06-12-19, 09:48 AM
Wh0pp3r
Wh0pp3r's Avatar
P0101
Mass Airflow Sensor Circuit Range / Performance
P050B
Cold Start Idle Air Control System Performance
P117B
Direct Injection Fuel Performance
Old 06-12-19, 08:48 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,853 Likes on 2,337 Posts
Originally Posted by Wh0pp3r
P0101
P050B
P117B
Yes, that could be a leak in the PCV system which is what the AOS is grafted into.
Quick Reply: Help with RR Racing Air and Oil separator
