Pothole Trouble
Old 02-26-17, 03:45 PM
nks979
nks979's Avatar
Originally Posted by mindcrime
i'm now excepting all the rattle and nosies on the IS F. i just turn off the radio and listen to noises as i drive around in SoCal streets.
Ive given up with my interior rattles, I'm going to try getting them fixed when it's apart for the airbag recall but till then I just live with it, somehow still audible over bazooka exhaust and music
Old 02-27-17, 06:28 AM
Vervish
Vervish's Avatar
I was lucky up until this happened - I had zero interior rattles. Overall it is not too bad - I only hear it at very slow speeds and when entering steep driveways.
I can live with it.
Old 02-27-17, 07:01 AM
Evil Teo
Evil Teo's Avatar
Vervish I hope it isn't the pothole you exit off of parkway and onto morris ave by toys r us? So you said suppension is fine and wheels and tires. I hope u find the noise and fix it. The potholes and roads by is is getting wicked due to construction...ugh I hate it!!!
Old 02-27-17, 07:07 AM
Vervish
Vervish's Avatar
Not that one - it is at the turnpike entrance off of 78 - you need to stay on the far, far right before the toll to avoid it. I saw it yesterday, looks like the drainage grate that extends the length of the tolls broke off near the center.
Old 02-27-17, 07:09 AM
Evil Teo
Evil Teo's Avatar
ahh that one...i usually go left as I take the express...waze did warn me of the pothole but I didn't come across it.
Old 03-29-17, 12:38 PM
Vervish
Vervish's Avatar
So creak noise is still present when entering driveways - does anyone have a photo of the front passenger side with fender removed? Cannot find one online.
Trying to determine what could be creaking under/behind the fender itself.
Old 04-01-17, 08:50 AM
Vervish
Vervish's Avatar
This is the noise I am getting when I lower the car on a jack.. coming from the fender.
Old 04-03-17, 01:50 PM
Vervish
Vervish's Avatar
New video from inside..
Old 04-03-17, 04:41 PM
Joker4096
Joker4096's Avatar
Weird, do you see any cracked welds anywhere?
Old 04-03-17, 06:52 PM
Vervish
Vervish's Avatar
All of the fender support brackets look ok as do the body seams that I can see. The noise sounds like it is coming from right where the first vid focuses on, the second vid is the same area from under hood. I am stumped.
i will need to remove fender to see what it could be. It is annoying as hell when entering/exiting driveway.
Old 04-05-17, 06:13 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
I'd bet it's a bad spot weld. I got rid of a Celica GTS and bought a Supra in 1994 for this reason. Found the same problem on a hatch in a Scion tC a buddy owned.
Old 04-05-17, 07:18 AM
Vervish
Vervish's Avatar
Unfortunately, I think so too - I suspect it is a bad weld somewhere on the part circled in red on this photo. At least that is where the noise seems to be coming from.
Other than the general annoyance of the thing, not sure how much structural rigidity I may have lost. I do not feel any difference.
I plan on going back to the body shop and have them remove the fender and re-weld if possible.
Old 04-05-17, 07:45 AM
Joker4096
Joker4096's Avatar
Yea with the fender removed and they lower the car, if the noise is still there it's a weld probably right where you are showing.
Old 04-05-17, 08:15 AM
Vervish
Vervish's Avatar
I hope so - that looks to be the only welded part in the neighborhood, everything else looks like unibody.
Old 04-22-17, 05:27 PM
Vervish
Vervish's Avatar
To close the loop on this....after spending every weekend investigating the problem, the problem is solved!
The area circled in red needed to be lightly pried away from the chassis. When I hit the pothole the fender shifted and either tightened the clearance between the chassis and the bracket or somehow loosened a portion of the weld. It caused the bracket to rub on the chassis and created binding noise heard in the vid.
Car is now back to normal, no squeaks, creaks or anything else.
Quick Reply: Pothole Trouble
