New owner checking in
Old Dec 26, 2016 | 05:36 AM
cleethree's Avatar
cleethree
Originally Posted by knshro13
I'd change fluids. The mileage is super low, but you never know when that last time it was touched. probably never. For example, moisture can work its way into the lines and contaminate brake fluid too.
I'd highly doubt moisture made it into the brake lines. The car was garage kept and never went out in inclement weather. Are there other reasons or theories? The oil was the only fluids that were changed and done regularly.
Old Dec 26, 2016 | 07:04 AM
mikersoft's Avatar
mikersoft
Congratulations & welcome aboard!
Regarding brake fluid.. The moisture can accumulate over time, regardless.. So, it's a good idea to at least bleed the brakes since it's likely the original fluid from the factory, which is now over 5 years old.
From Wikipedia:
Glycol-ether (DOT 3, 4, and 5.1) brake fluids are hygroscopic (water absorbing), which means they absorb moisture from the atmosphere under normal humidity levels.
-Mike
Old Dec 26, 2016 | 07:49 AM
cleethree's Avatar
cleethree
Thanks for the recommendation. I'll change out the brake fluid.
Also the brake squeak sometimes during slow braking. My SA says there's no TSB for the brakes but I read that there is one here, albeit on an old thread. Is it because I have a 2012? I'm thinking maybe the later models already have the new pads and shims.
Old Dec 28, 2016 | 11:21 PM
Apexsports's Avatar
Apexsports
Beautiful color combo...congrats on the pick up.
Old Dec 28, 2016 | 11:46 PM
PDP180180's Avatar
PDP180180
Very nice!
If you want performance gains from the exhaust, you'll be needing to change your headers. There are a few choices in this regard, most go with either PPE or SIKKY, but there are some rare options out there like Novel if you have deep pockets!
Congrats on the purchase though dude, nice find for sure.
I'd also look at getting the USRS and the AOS and maybe the titanium intake from RR-Racing.
First one improves handling, other two remove unwanted oil from the intake system. The titanium intake also happens to look amazing! Lol.
Hope you and the family enjoy many happy miles together.
Cheers.
Peter
Old Dec 29, 2016 | 03:53 AM
Jz39's Avatar
Jz39
Originally Posted by PDP180180
Very nice!
Cheers.
Peter
??? Exhaust gives nice gains all on its own.
FsportLuna
RC - 1st Gen (2015-present)
16
Mar 9, 2017 06:19 AM
JGreenwood
IS - 1st Gen (2001-2005)
Jul 6, 2015 09:32 AM
whyzee125
Jun 26, 2013 12:52 PM
Menace
Feb 5, 2010 09:07 AM
Idoktr
Apr 23, 2008 08:05 PM
