Valley Plate Class Action
#31
Discovered it at 93k, no warranty... Quoted $1500 to fix. I also have a oil leak at on the timing chain cover $2000 to fix.
Currently at the dealer waiting for corporate to review my complaint to see if they will assist in the cost
#35
Tech Info Resource
lobuxracer (09-18-20)
#38
Tech Info Resource
Helps make sure the tube o-rings are properly in place. Especially for timing cover r&r.
The following 2 users liked this post by viprez586:
ISF4life (09-18-20),
#41
Tech Info Resource
Thanks for the tip. I was planning to replace the coolant pump anyway. It's got well over 100k miles on it now. Lexus replaced it pretty early on because it was failing prematurely - a known issue with the '08s for sure.
#42
Any evidence of these failing after being fixed by lexus? Was the issue an inferior gasket material that has been replaced?
#43
Is this problem a 'eventually will fail' on the isf, or is it something that affects some cars and not others? I have a 2010 (since new) and haven't had any problems at all (its a canadian car). 100 000KM.
#44
Received 1,059 Likes
Its a black Lexus / Toyota FIPG sealant... @lobuxracer goes in depth on the sealant to use and not to use.. (can't find the post)
There have been some minor reports of a 2nd failure, my guess is sloppy tech / prep work..
All dealerships warranty their work for 12 months unlimited miles.. Most IS F's OEM warranties have lapsed by now.
If nothing breaks and the knock sensor harness is not flooded by coolant, the only 2 parts to replace are the 2 - O Rings found on the transfer tube.
New coolant recommended by default.
Joe Z
#45
