Steering issues
The other really important thing I see many alignment techs miss is tire pressure. You absolutely must adjust your tire pressure to be the same in all four wheels. The factory spec is 36 psi all around and their measurements are based on a car with the factory pressure. If you have variances in tire pressure your alignment numbers will be off. I have seen MANY alignment techs assume tire pressure is good. It's a bad assumption.
thank you for your response. i'm not familiar with thrust angle, therefore i can't give my feedback on it. I'll call the alignment shop and ask about subframe alignment, if they don't know i'll call around for a shop that can. the tire pressure was off and i didn't have it check prior to alignment, thus it's probably off. the rears were like at 42 PSI-same shop put on tires the week before and i didn't have them checked prior to leaving as i had been there a while and was tired. I'll call the shop and ask tell them i'm not happy with the alignment and see if they can adjust with all tires at 36 PSI: will the later help? then ask about subframe alignment, but i doubt they do that.
suspension: KW V3 and RR Racing LCA Bushing, rear F-sport sway bar.
thank you for your response. i'm not familiar with thrust angle, therefore i can't give my feedback on it. I'll call the alignment shop and ask about subframe alignment, if they don't know i'll call around for a shop that can. the tire pressure was off and i didn't have it check prior to alignment, thus it's probably off. the rears were like at 42 PSI-same shop put on tires the week before and i didn't have them checked prior to leaving as i had been there a while and was tired. I'll call the shop and tell them i'm not happy with the alignment and see if they can adjust with all tires at 36 PSI: will the latter help? then ask about subframe alignment, but i doubt they do that.
p.s. current tire PSI is 38, which i had corrected after alignment.
I am in the Orange County area. South OC in Lake Forest. I wouldnt mind that at all. i didnt feel it at all to and from work today but on Wed it was definitely there.
Another thing to look at is rear toe and rear toe balance. The earlier years had more bump steer but it can still be an issue with later models. It's truly a 4wheel steering suspension geometry with the rear toeing in under compression. By lengthening the rear toe link, we reduce the amount of steering input that the toe link provides. This creates a lot more stability at high speeds and cornering. It also eliminates that waggle you might feel when you hit a bump while cornering that has a tendency to upset the car. We have always advocated slightly more negative camber rear with longer effective to link set and static toe settings to 0.05 per side. The symmetry of the rear under load is very important to the overall balance of the car. Rear Toe links and our adjustable LCA are what we suggest.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Got my car back from the dealer... Of course they can't replicate it.. I will have to take it out again, but I went on a longer drive and I think I noticed something: that it happens only from going right to left.
