Will the ISF run well with a blend of e85?
Old 10-24-16, 06:09 AM
Vervish
Vervish's Avatar
I ran 100% E85 on my subaru for over 3 years - not a single issue with fuel lines (or anything else).
The E85 does not cause the corrosion - it is the water content within the fuel. All modern fuel systems are designed to withstand the corrosion caused by E85 or regular gas.
I need to try to add some E85 on my F..
Old 10-24-16, 07:07 AM
MileHIFcar
MileHIFcar's Avatar
Originally Posted by ross3857
Is this with the RR tune or 30/70% on stock tune?
I'm FBO so on the tune, but I also did this with the stock tune as well and benefits were present then, though not as much as with the tune.
Originally Posted by jat0223
How long have you guys been doing this? I would like to try it but I'm worried about corrosion of the fuel lines/seals over time.
I've been blending since July, first on the stock tune, and now with the tune/FBO and it's readily apparent the benefits with the tune as stated with my timing advance
Like Vervish said above don't buy into the whole scare hysteria that you've been told/heard about corrosion caused by E85, all modern fuel systems can handle ethanol in the fuel system and are designed not to corrode.
Old 10-24-16, 08:41 AM
ISFTOMMY
ISFTOMMY's Avatar
So im guessing you cant fill up completely with E85 so how much should u put in? do u need to use race gas or just 93 to mix it.
Old 10-24-16, 09:19 AM
MileHIFcar
MileHIFcar's Avatar
Yea 100% E85 will require more fueling than what our fuel injectors can provide would be my guess? I think if someone was going to want to run 100% E85 with say the new S/C from RR-Racing then yea you will need larger injectors (both port & direct).
No race gas needed, the E85 is your race gas with an octane rating of 105, so just mix with your premium 93 to obtain your octane blend. With our 91 octane (highest we can get here in Co, along with Cali) the 30% blend I do gets me to about 95 octane which the tune and the car loves!!
Old 10-24-16, 09:26 AM
juanmedina
juanmedina's Avatar
mixed with 93 oct of below. Start with 30% E85.
Old 10-24-16, 09:31 AM
ISFTOMMY
ISFTOMMY's Avatar
ok so 11.83 gal. of 93 ( regular fuel) and 5.07 gal. of E85 if u could fill up all 16.9 gal in the tank? so IRL like 11 gal. of 93 and 5 gal of E85
Old 10-24-16, 09:55 AM
semnosNSX
semnosNSX's Avatar
MilleHiFcar - you keep saying "the car loves it", can you please provide a bit more detail on why you think the car loves it? Does it feel more responsive? Does it idle smoother? Does it have more top end power? Etc. Etc..... thanks!
Old 10-24-16, 09:57 AM
idoke1
idoke1's Avatar
Well, today I put in 4.5 gallons of e85 and 11.6 gallons of 91 octane. After some pulls in 8th gear and some high speed 4th gear loads, I can honestly say my KCLV are all above 20. The first KCLV is actually @ 24. The second one is @ 21.7. This is definitely some GOOD STUFF
Attached Thumbnails Will the ISF run well with a blend of e85?-20161024_093815.jpg
Old 10-24-16, 10:01 AM
Joker4096
Joker4096's Avatar
This is what i wanted to know. Good stuff. One question, did you drive you car many miles after the counter went down to zero? when i get to 0, the car usually only take 14.xx gallons to fill.
Old 10-24-16, 10:06 AM
idoke1
idoke1's Avatar
I was way below 0 mark. I really wanted to make sure I get as close to 16 gallons as poissible. When the miles left for gas read 0 for me, I drove an extra 25 miles. Keep an eye on your miles. I did not drive like a lunatic when gas was @ 0 mIles left. Take it slow and easy.
Old 10-24-16, 10:12 AM
Joker4096
Joker4096's Avatar
yea i know once it its 0 you hit the 2 gallon reserve. Also, did you reset your ecu on that fill up to get the kclv up?
Old 10-24-16, 10:15 AM
idoke1
idoke1's Avatar
Honestly, I did not reset my ECU. It's probably better if I did but I'm happy with the results.
Old 10-24-16, 10:29 AM
Joker4096
Joker4096's Avatar
yep, i am going to be doing the same next fill up and want to make sure i get kclv numbers like that.
Old 10-24-16, 10:52 AM
SoulFreak
SoulFreak's Avatar
Very interesting gentlemen! Keep the reports and results coming in as some of us don't Data log.
Old 10-24-16, 11:10 AM
MileHIFcar
MileHIFcar's Avatar
Correct, if you were bone dry. But like others have stated when your miles to empty hits 0 you still have a 2 gallon reserve so I calculate on filling up the majority of the time at about 14.5-15 gallons, so my E85 is between 4-5 gallons based on my gauge. I'v gotten use to how much it'll take even at 1/4 tank.
Sorry I wasn't more descriptive, yes responsive like I have a Apexi throttle controller on, instant response from the motor! Then the car pulls and pulls hard with the FBO list of mods I have. And finally what Rafi said when I data logged for him which is the proof positive was the fact that I'm running more timing than other ISF owners here locally that were initially not running E85 compared to my logs, hence why he said to start blending for us guys at altitude to see the most benefits from this tune.
I did this originally because if you guys remember we are at 5,280ft + and were having problems getting our KCLV's up to par with the sea level guys. So Rafi said if only you guys had access to race fuel, or run octane boost with the tune then you would/should see some benefits from the increased knock resistance. So that's where the E85 research started for me and then me diving right in!
Awesome! Glad to hear your numbers responded accordingly
Yep I up usually and it takes about 14- 14.5 gallons when I fill and do my calculations
Will do!
Quick Reply: Will the ISF run well with a blend of e85?
