Questions on BC coilovers/rubbing
Old 10-14-16, 07:19 AM
Vervish
Vervish's Avatar
Thanks. They will go up pretty high - probably very close to stock.
If you do not plan on going lower - you should also look into Bilstein B8 HD shocks. I believe they are an upgrade over stock and can be used with stock springs.
More info here: https://www.clublexus.com/forums/is-...on-2008-a.html
Old 10-14-16, 07:45 AM
Jz39
Jz39's Avatar
Originally Posted by Vervish
No camber or toe mods, I am running Figs LCA bushings tho.
Camber is way off on all 4 corners - but I think it is less than - 3 degrees. That is not enough to affect tire wear. Toe is aligned to 0 degrees all around to eliminate/minimize tire wear issues.
Here is another angle..
Perfect drop!! So you got the toe in spec with factory adjustment. That's excellent. These are the pics I really don't need to see because they are going to end up costing me money when the obsession to lower kicks in!
Hamilton92
IS F (2008-2014)
04-21-15 01:35 PM
RSXiMUS
IS F (2008-2014)
01-29-15 09:16 AM
mjh09e
Suspension and Brakes
13
01-31-13 12:32 PM
Mikerx80
08-10-12 09:52 PM
Willdb15
05-02-10 12:11 PM
Quick Reply: Questions on BC coilovers/rubbing
