ZE40 F 19x9.5 +22 and R 19x10.5 +22 ISF Fitment? Help
That crazy offset is not only for an aggressive stanced look, but also that deep concave. I'm guessing the OP wants a more concaved look for his wheel. So even if he changed the offset to something less aggressive and fits better, he won't achieve the desired look.
I actually have this same offset but on a different Volk(which is for a different car and aren't mounted yet). I should mount and test fit them on the rear of my ISF so the OP knows what to look forward to.
67THUMPER (08-23-23)
I was gonna say the fronts are fine, though not the best offset for optimal performance, but the rears will need some work. It's doable, and purely more aesthetics than anything performance oriented, but it can be done. I've always felt +35 was probably as aggressive as one can go without altering the camber. I like that you want a concave wheel, and the ZE40 was definitely on my list, especially with that shade of blue, but the offsets were a bit hard for me to pull off since I don't want anything but natural camber.
Since you already purchased them, you might as well try it out and see if you can ride with it. If not, there will still be some guys looking for that same wheel and sizing, so there's always that option. Best of luck to you!
Love the bronze shade as well. They did it right with these color options. I like the bronze on black look. Hope it all works out in the end for you.The ZE is a great choice, so even if there's some work that has to be done, you'll love them. Every time I see them, they're still an eye catcher to me.
Wow looks great! Are those Spec 1 and Spec 2 face?
Here are a set of ZE40's on my ISF - 19x8.5 +33 fronts and 19x9.5 +40 rears with 245/35 and 275/30 respectively.
Just a mild rear fender roll for clearance is all was needed.
Regards,
Sameer
Regards,
Sameer
