Side Mirror Shakes
Old Mar 22, 2016 | 09:17 AM
isfdave86's Avatar
isfdave86
Originally Posted by Justin727
You probably accidentally damaged the innards. This is very easy to do especially since it's all plastic.
Has happened on my 4R and my GX. I bought Used/New mirror assemblies
I was super careful taking them off. Someone suggested I might have damaged the posts that move the mirror. If that's the case I might throw up
Since this is a possible solution, does anyone have the Toms LED side mirrors?
Old Mar 22, 2016 | 09:20 AM
isfdave86's Avatar
isfdave86
Originally Posted by Rickna
Thanks. Like these from ijdmtoy...
Those have a weird shape. It's a rather small place to place them. From what I've seen on here these are the ones people suggest, and they're the ones I went with.
http://www.vleds.com/bulb-type/inter...pf-w-6k-n.html
Old Mar 22, 2016 | 09:39 AM
Rickna's Avatar
Rickna
I have the flat ones in the visor lights, they work very well.
Old Mar 22, 2016 | 05:39 PM
jlam86's Avatar
jlam86
I am sure it's cause the mirror isn't pressed in all the way. It's really hard to get your fingers behind the mirror to snap it back into place. I had the same problem but once i got it into place properly, it was all good again
Old Mar 22, 2016 | 08:34 PM
isfdave86's Avatar
isfdave86
FIgured out the problem. The bottom clips weren't popped in completely. Guess I was afraid of pushing too hard and breaking my baby already. lol. thanks for the help all.
BTW, does anyone have a suggestion for a well fitting blind spot mirror? The one I picked up from parts store looks odd with the shape of our mirrors
Old Mar 23, 2016 | 05:03 AM
Rickna's Avatar
Rickna
I've been looking around for the same. I haven't found the right ones yet either.
Old Jun 7, 2016 | 08:10 PM
Bigjon3475's Avatar
Bigjon3475
I tried an advanced search but did not see anything relating to this. When I have the side mirror switched to driver side and put car in reverse the mirrors aim down as they should but upon switching it to drive the drive side mirror goes back to its normal position but the passenger overshoots and aims up at the sky. Before I go ripping the car apart I'm wondering if anyone else has had this issue? Thanks!
Old Jun 7, 2016 | 10:16 PM
flowrider's Avatar
flowrider
Veteran: Air Force
I'm happy with mine. My Girl Friend found them a couple of years ago. They do the trick for me.
Lou
Old Jun 8, 2016 | 12:25 PM
foxprime's Avatar
foxprime
Glad you found the fix. Same thing happened to my car. Just needed a little push and shove!
Old Jun 8, 2016 | 12:32 PM
Vervish's Avatar
Vervish
My interior rear view mirror is the one vibrating all the time. Loud music or if I have the windows open at anything about 40 mph makes it shake bad.
Old Jun 8, 2016 | 01:17 PM
isfdave86's Avatar
isfdave86
Mine's been doing that too. I'm gonna have to take a look, it started after the mirror was removed for tint
Old Jun 8, 2016 | 02:56 PM
Rickna's Avatar
Rickna
If tightening up the hardware doesn't work try making a shim.
Old Jun 8, 2016 | 04:28 PM
flowrider's Avatar
flowrider
Veteran: Air Force
Actually there was a TSB on this 7 or so years ago.
https://www.clublexus.com/forums/is-...ew-mirror.html
I had mine done way back when. The affected mirror had the buttons on the bottom of the mirror facing down. The replacement mirror has the buttons below the mirror facing straight back.
Lou
Old Jun 9, 2016 | 05:49 AM
Rickna's Avatar
Rickna
According to the TSB this was done on my F by the original owner. Although, it is the older style mirror. Besides, after the work I did I wouldn't want anyone else touching it.
Droid13
RX - 3rd Gen (2010-2015)
Aug 29, 2014 07:21 AM
SilentWish
Sep 1, 2010 08:33 PM
yellowssm
Jun 23, 2006 05:39 PM
satxrx
RX - 1st Gen (1999-2003)
18
Apr 26, 2002 01:35 PM
