Michelin PSS on OEM size
Old Mar 3, 2016 | 10:37 PM
  #91
Orthodoks's Avatar
Orthodoks
Originally Posted by bnizzle87
I'm pretty sure it's just $100 off a purchase of $400 or more, as it doesn't matter how many tires need to be purchased. I've helped a few friends with new tires this way, and the savings sure add up. This deal comes relatively on occasion, and it varies by brands and sizes. But essentially to make this a good deal...say for instance you're purchasing Michelin PSS. Two tires will already be over $400, so purchase, say the 2 front tires for $530 (stock size, PSS) the amount will be $430 after instant rebate. Do this again for a second transaction on the rear tires, which will come out to $500, so it'll cost you $400. $830 for $1k PSS tires isn't a bad deal. It might not be a lot, but $200 can get you a decent amount of gas fill ups, detailing supplies, or even a track day with your F.
Again, the key is to make sure the deal is for PSS, which it may not be. Discount Tire/ America Tire varies its promotions, so as a consumer, pay attention to the deals that you want. Plus, there is no shipping or taxes applicable, unlike purchasing from say a Tire Rack or even in person at a Discount Tire store. Tires aren't cheap, but getting them at a slightly lower rate will help.
Your right. My dyslexia kicked in and read set of tires and wheels instead of select. I just tried to check out with different combos of 2 or 4 PSS and many other brands, it wouldn't let me apply the coupon at checkout. Hmm... Weird.
Old Mar 3, 2016 | 11:13 PM
  #92
bnizzle87's Avatar
bnizzle87
It will only be a specific set of tire widths or manufacturers.
According to the site, Michelin PSS in 225/40-19 is not available for the promotion right now, but PSS in 255/35-19 is still available for purchasing. You would need to purchase two, use the coupon code for this current promotion, and have it all streamlined through PayPal. It's a bit tricky, but if at any point you don't see the $100 off your total, do NOT confirm the order.
http://www.ebay.com/itm/1-NEW-255-35...item5406707e9d
Old Mar 5, 2016 | 01:59 PM
  #93
F_Throttle's Avatar
F_Throttle
Has anyone purchased from this ebay vendor?
Old Mar 5, 2016 | 02:19 PM
  #94
Fivepoint0's Avatar
Fivepoint0
Bought two sets from them.
A+ very fast shipping
Old Mar 5, 2016 | 07:42 PM
  #95
lobuxracer's Avatar
lobuxracer
Tech Resource
Kind of pricey without the discount if you ask me.
http://www.discountedwheelwarehouse....1567&pID=59853
Old Mar 7, 2016 | 03:59 PM
  #96
F_Throttle's Avatar
F_Throttle
Are people going to zero toe (front) on 245/275 setup?
Old Mar 8, 2016 | 02:22 AM
  #97
Jz39's Avatar
Jz39
I'm interested to know this as well. Just about to pull the trigger on new tires and will be going the 245/275 PSS route.
Also, how much heavier is the steering feel with the 245/275 setup. On my G coupe I have this exact setup for summer and when I go back to stock 225/245 in the winter it's almost nice to have the light steering feel back and the responsiveness of the narrower tires. But the F really needs the extra meat to put the power down.
Old Mar 9, 2016 | 10:14 AM
  #98
Jz39's Avatar
Jz39
I'm curious--how come no one has mentioned a 235/40/19 and 265/35/19 set up?
It interesting because this would be a compromise between stock and 245/275, and on the 08-11 wheels it might still keep a bit more of the wrapped look.
Also, in this scenario, each tire is only 0.3" greater in diameter than stock.
Lastly, on Tirerack, there is a PSS 265/35/19 listed as NO Porsche that actually has the same treadwidth as the 275 PSS--must be a more square tire--and this tire is a Best Seller and actually the cheapest of all the 265/35 PSS variants.
Thoughts? I feel like if I had the 2012+ wheels I would do the 245/275, but on 2011 wheels these sizes might be a perfect compromise.
Old Mar 13, 2016 | 11:16 AM
  #99
mindcrime's Avatar
mindcrime
my F came with 255/35 and 285/30. they are Falken tires. the rears will need to be replaced in a soon and not sure which brand to get. i want a little more meat to the tires.
Old Mar 13, 2016 | 11:58 AM
  #100
bnizzle87's Avatar
bnizzle87
There is plenty of meat with the 285/30 out back, even with the 255/35. But depending on the size of the wheel, I would attempt 295/30. When I saw you yesterday, we briefly discussed the wheels. So if the sizing permits, I'd go with 295s. It keeps it in line with the stock parameters of the OEM tire set up. Michelin PSS is probably the best bang for your buck, although others will have their preference as well.
Great meeting you yesterday, my friend!
Old Mar 13, 2016 | 12:50 PM
  #101
I8ABMR's Avatar
I8ABMR
255/295 is the same OD ad oem. Thats why I went with that when I did aftermarket set up. I dont like the way the 245/275 makes the fender gap look bigger to me. Its subtle but I notice .
Old Mar 13, 2016 | 08:28 PM
  #102
mindcrime's Avatar
mindcrime
great meeting you as well sexy, oops, i meant Brian lmao. i'll definately consider a 295/30 when i replace the tires. i'm not sure of the width of the rims or the offset, but i have no rubbing other than the front when i backed into the driveway and turned the wheel full radius. i'll probably powder coat the wheels, thinking of black chrome. anyone your recommend? i'll measure the wheel at that time and see if a 295/30 will work, otherwise i'll go 285/30.
Old Mar 13, 2016 | 10:52 PM
  #103
bnizzle87's Avatar
bnizzle87
lol The gf was just happy that another girl didn't call me that, though I kinda like seeing that defensive side of hers from time to time.
As for the powdercoating, many friends have taken their wheels to Primo Powder Coating in Huntington Beach. It might be a little far, but having seen the results, their work appears to be top notch.
Definitely take a look see at the wheel specs. With 295s, you'll probably need a mild roll just to keep from rubbing on hard dips.
Old Mar 14, 2016 | 06:31 AM
  #104
SubOrbital's Avatar
SubOrbital
A 10" in the 50 offset region will should get you a 295 section width tire, though that's the minimum rim width for that size. The PSS tends to have a lot of tread width for the section width too, so you'll probably have to get them fitted a bit. I believe some folks have run this size tire on OEM RC-F wheels.
Old Mar 14, 2016 | 08:28 AM
  #105
mindcrime's Avatar
mindcrime
HB is close to me. I know a guy that does fender rolling, he was going to roll fenders on my GS, but he advised against it b/c it would leave dimples on the fender wells. he didn't realize I had a GS though. long story short, I bought to tall of a rear tire.
do you know if primo dismounts/mounts tires?
