ISF drop question
Old Jul 26, 2021 | 10:22 PM
  #31
lobuxracer's Avatar
lobuxracer
Tech Resource
Thanks for wrecking my day by telling me I'm procrastinating and it's costing me money...
Old Jul 27, 2021 | 05:49 AM
  #32
Jwconeil's Avatar
Jwconeil
We are both in that boat together. If we bought end of last year when I pm’ed you, we would have collectively saved a pretty penny.
Old Jul 27, 2021 | 07:01 PM
  #33
McPierson's Avatar
McPierson
Originally Posted by steeven001
Hey McPierson did you end up cutting the springs and testing spring rates after?
I've been thinking about doing this to the front for a small camber gain and spring rate gain
funny story…. Not really.
I did cut and test one spring which I cut every 3” around the circumference and measured the stack height and also did the load testing.
it was so much work and I was actively destroying my springs. So I sort of abandoned the project. Let me look at the data on the spring and I’ll report back.
Something to consider, the OEM has a sort of half coil that is wound at a lower slope to interface with the bottom perch. So if you cut much the bottom perch might be pretty suspect.
Old Jul 28, 2021 | 05:09 AM
  #34
Jwconeil's Avatar
Jwconeil
Isn’t one end of the coil tangential? If not, we can’t cut them. If so, we can only cut the tangential end.
Old Jul 28, 2021 | 08:36 PM
  #35
McPierson's Avatar
McPierson
Are you saying cut the top of the coil?
Old Jul 28, 2021 | 11:55 PM
  #36
lobuxracer's Avatar
lobuxracer
Tech Resource
You could always cut it out from the middle and weld it...
j/k...
Cut the end that is square cut. If the top is ground flat, cutting it will be dicey. I'd keep the cuts small - an inch at a time - so you don't get a rigid ride on out of control damping.
fathorsejr
Mar 20, 2016 07:13 AM
IS-Fast!
IS F (2008-2014)
50
Nov 3, 2012 09:36 PM
KickItOut
Aug 21, 2012 01:08 AM
Supraman16
IS F (2008-2014)
May 8, 2009 04:16 PM
