Seeking knowledge on this car
Are you sure about this?
https://www.clublexus.com/forums/is-...ml#post3363418
JoeZ's tests showed they did not fit.
They always come painted. He may have had something else like carbon on these before an took it off. Its obviously been modded.
Like everyone is saying becareful, Not sure how those wheels wood fit. Calibers are to big.
They are a direct fitment do a search few member with ISF used ISx50 rim as winter tire without messing with the hub or anything.
https://www.clublexus.com/forums/is-...s-fit-isf.html
I don't what to say i see member running them without issues like current member CalitriSC on the link
https://www.clublexus.com/forums/is-...ht-now-24.html
ISF wheel only fitted IS250 didn't clear the IS350 caliper to be correct on that note.
It looks like it has Brembo brakes. Brembo brakes require IS F front hubs because the spacing is different, and the 2IS wheels were problematic with those hubs (if I am remembering correctly). As I recall it was easier to put the IS F wheels on a 2IS than it was to go the other way around.
Maybe they're running spacers? The back half of the inside of those wheels are wider. There's like a reverse lip if you know what I mean
There are several reasons this car is at the Auction, as all cars there are..
I tried it twice in the past years, and will never do it again... Learned from experience...
JMHO
Cheerio, Zale
