Rubbing against the fender liners
Old 06-03-15, 05:03 PM
TISF
TISF's Avatar
Default Rubbing against the fender liners
I'm lowered on coils with 20mm spacers in the front and I'm rubbing my liners not a whole lot but still bothers me. There's a lot of people here with dropped and flush "F's" so what have yall done? Or do yall just let it rub away
Old 06-03-15, 05:10 PM
subiepunk
subiepunk's Avatar
I had some of the fender liner in front cut when I had the fenders rolled. Otherwise I've just let it rub. only rubs on hard dips and turns at full lock
Old 06-03-15, 06:22 PM
I8ABMR
I8ABMR's Avatar
go to 15mm spacers or trim. You are pushing the limits with your set up
Old 06-03-15, 08:00 PM
TISF
TISF's Avatar
Old 06-03-15, 08:01 PM
TISF
TISF's Avatar
Raised it up a little made a big difference on dips and full turns
Old 06-04-15, 10:46 AM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
trimmed it and let it rub off for the past 10000 miles lol.
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 06-04-15, 12:09 PM
krue92
krue92's Avatar
I had 15mm spacers and now I have 20mm on the front and it rubbed with both only in reverse at full lock. I haven't done anything and it really doesn't bother me. Some people have trimmed the inner fender liners though to fix the issue.
Old 06-04-15, 12:53 PM
Zelfiris
Zelfiris's Avatar
I had my rear fenders rolled at a reputable shop. The results were sub par. I touched up the exposed plastic and metal with touch up.
I'm not sure if rubbing your tire away is safe
Old 06-04-15, 05:17 PM
Sean
Sean's Avatar
And that's the main reason I went with coilovers. Assuming the pics are after your adjustments the ride height looks great also.
My 370z with Eibachs before my ISF I actually wore completely through the fender liners. I just can't let myself treat the F that way.
Old 06-04-15, 06:33 PM
jlam86
jlam86's Avatar
try using a heat gun and shaping the fender to clear.
Old 06-05-15, 03:07 PM
TISF
TISF's Avatar
Well I tried shaping the fender with the heat gun already, didn't work at all, I think the problem is just the fender liner. I'm just going i let it rub away , it only rubs at full lock reverse and full lock whenever I make a U-turn
Old 06-05-15, 08:26 PM
jlam86
jlam86's Avatar
When I had the 15mm spacers in, 245 tires and swift springs in, it was already rubbing when it is almost at full turn and you reverse. so with the 20mm, pretty sure you're going to have to get quite artsy lol
Old 06-05-15, 09:30 PM
Sylvan
Sylvan's Avatar
I had 265/35 on 10" wheels and they rubbed like crazy. I went to 255/35 and it still rubs but only like you said when it's on full lock.
Old 06-06-15, 04:23 AM
Vervish
Vervish's Avatar
I have the same exact setup and issue. It rubs on the vents in the passenger side wheel well..it's a chattering noise as it rubs the vents.
Old 06-06-15, 09:51 PM
TISF
TISF's Avatar
Maybe I'm too low then I see sylvans car and I'm about another half inch lower from fender to tire. So I migt just have to raise it up. But it's just temporary because the front of the car looks so empty without a lip
Quick Reply: Rubbing against the fender liners
