First Mod! LED Turn Signals With Video
Old Feb 7, 2015 | 11:01 AM
yjk1975's Avatar
yjk1975
Looks great. Sounds kind of complicated.
Old Feb 7, 2015 | 11:44 AM
Rickna's Avatar
Rickna
Not at all. It's simply a PnP relay swap.
Old Feb 8, 2015 | 09:45 AM
Raybean's Avatar
Raybean
look great. i might look into getting red ones
Old Feb 8, 2015 | 10:26 AM
Dupshaw123's Avatar
Dupshaw123
I am interest in this mod BUT…...I have heard of people having issue with the LED lights not responding when you press the lock and unlock button when the car is parked. Can anyone report on this? Thanks
Old Feb 8, 2015 | 10:54 AM
justjosh's Avatar
justjosh
My lights still flash when I lock and unlock the car.
Old Feb 8, 2015 | 01:30 PM
Rickna's Avatar
Rickna
No issues here either.
Old Feb 9, 2015 | 05:55 PM
Beachtyme's Avatar
Beachtyme
Nice, I like the LED look for the turn signals.
Are the LED part #'s the same for front and rear amber blinkers?
Old Feb 10, 2015 | 06:26 AM
justjosh's Avatar
justjosh
Both front and rear turn signals use 7440 bulbs.
Old Feb 11, 2015 | 12:22 AM
usa5655's Avatar
usa5655
looking great ! im waiting for my LED turn signals from IJDMTOY
Old Feb 14, 2015 | 10:45 AM
Beachtyme's Avatar
Beachtyme
The rears were easy enough, any tips on doing the front turn signal bulbs?
It appears that the bulb inserts from the bottom in to the headlight housing.
Old Feb 14, 2015 | 10:53 AM
prada_g's Avatar
prada_g
The front bumper has to come off to change the front turn signal bulbs....I tried to reach through the fender liner when doing mine but the bumper support was in the way .
Old Feb 14, 2015 | 04:17 PM
Beachtyme's Avatar
Beachtyme
Thanks for the info, looks like I won't be changing the fronts out any time soon.
Edit: Forgot to add that the rear LED's are a nice improvement. My reverse LED's weren't working, I had to pull them and expand the wire on the LED base a bit for them to make good contact.
They light up now, very bright over stock. I still have an image of a very bright white LED in my line of vision.
Old Feb 14, 2015 | 04:39 PM
Rickna's Avatar
Rickna
I will be doing the front signals soon. I have to remove the front bumper to install laser shifters anyway, I'd like to do everything at once. The rear signals, reverse & bumper lights I did a few months ago.
Old Feb 14, 2015 | 06:34 PM
justjosh's Avatar
justjosh
I got my front turn signal LED bulbs in the other day and I will be taking off the front bumper tomorrow to install them. I will post a video after I get them installed.
Old Feb 14, 2015 | 07:04 PM
OutCaster's Avatar
OutCaster
seems like if you get this one: http://store.ijdmtoy.com/No-Hyper-Fl...s-p/20-001.htm the led flasher is built in and you don't need a separate module to prevent hyper blinking?
