Dash Cam installation Suggestions
Just ordered a blackvue DR530 (front and rear camera), the cheaper predecessor to the DR550 which has GPS. I figured if you're in an accident, what good would the GPS function provide if you've already captured the accident. Also nabbed the power magic pro to hardwire/run it for 6 hours or 11.8v before it shuts off. Should be here in 2-3 weeks straight from Korea!
I have a Blackvue DR-650GW. Great cam, and yes the rear only records in 720P HD. But my tint is so dark in the rear that it doesn't really make a difference cause the image quality is going to be too dark anyways. I have the rear cam in there just for the sake of capturing some action, and don't count on it capturing any license plates. But in bright enough condition's it does capture plates.
if you want Full HD 1080P front and rear and don't mind a big *** display then get one of these:
https://www.youtube.com/watch?v=H5de7zgUhOI
I have it hardwired into the car and to do this you need one of these. This will allow you to use the camera's parking feature that records in standby when the car's ignition is off:
http://www.blackboxmycar.com/collect...c-pro-blackvue
There are 3 wires. Earth, Power and ACC. For earth I just tapped it up to some metal. Power I hooked it up to the power seats fuse. As for ACC, there is a direct fuse for ACC. The fuse box is a very small white box under the drivers side dash.
This is a good video outlining tapping into the fuse box and how to run wiring:
https://www.youtube.com/watch?v=seyOjGDxvqs
Thanks for the info,
Now I was looking at getting the power magic pro but the Cowon camera says that it gives you the settings to set your voltage setting so if the battery is running low it can automatically shut down.
I am still confused on what to set the voltage to, either through the power magic pro or through the camera itself.
Does anyone have more details on what voltage is a safe voltage to set the camera to shut off at?
However in my older cam setup it would go down to 11.3V and that is probably the lowest you should go as a saftey net. At 11.3V cut off my car did crank a little weak so I wouldn't suggest going any lower than that.
I purchased these "Add a fuse":
http://www.ebay.com/itm/ATM-LOW-PROF...E:L:OC:US:3160
Also Lukas voltage cutoff device, I think I have set mine to 11.8V:
http://www.ebay.com/itm/Free-Express...E:L:OC:US:3160
It's pretty simple on what needs to go where and which fuses to tap, but here is what my setup looks like:
Video sample of what can be captured. I have the Lukas LK-7900 ACE for 2 years now.
The power magic pro's lowest voltage setting is 11.8V before cut off.
What voltage would you recommend I set my cut off to if I don't want to risk having a weak crank? I don't necessarily need the camera for parking mode but I just want it hard wired instead of through a cig lighter.
event 20150201 133351 - YouTube
So you have the the camera connected to the Lukas voltage cutoff device and that is connected to the add a fuse correct?
also Why do you have "2 add a fuses" connected?
Finally would I need to buy a separate fuse to add to the "add a fuse"? or can I simply just put 1 fuse in (the one I've taken out of it's original location?)
Thanks for the info.
Thanks for the links
Lukas voltage cutoff device has a cigarette socket which you connect the camera into with the supplied power cable. The cutoff device has 3 wires, 1 for ground, 1 for ACC (power off when car turned off), and 1 for always on power. Yes, you will need 2 fuses total to insert into the "add a fuse" so will need to purchase extra fuses.
The voltage cutoff of 11.8V has worked for me the past 2 years with parking mode and still on the original car battery. Some people might differ, but it has been working for me.
Yes, the power cable is pretty long so i shoved it into the headliner pretty deep. I'm sure it can be yanked out of the headliner, but it's in there pretty good and so far so good for 2 years. Routed the power cable down the A-pillar. The A-pillar cover just pops off so you can route it behind the airbag down to the passenger fuse box. I used plastic tie wraps to secure the power cables in the A-pillar.
