Isf power question
Old Feb 3, 2014 | 03:18 AM
yishin's Avatar
yishin
Originally Posted by fstpassat
Good god, work on the English bud. You should have zero issues with a 370Z and be right there with an M3 DCT with you being bone stock. With mods, you should pull the M3 and outright rape the 370Z. 335's can be very fast, so it depends on what they have done and if they are running an E85 mix or not.
Where in Georgia are you?
Yes i will try my best to work on english
I am in atl ga near mall of ga
Old Feb 3, 2014 | 03:20 AM
yishin's Avatar
yishin
Originally Posted by digger08
Whut? Are you saying you think the USB stick has a virus and its affecting your car?
Digger08
Thats the only thing has been added? To the car after that i had a problem with isf will not start thing cranks but not start issue
Old Feb 3, 2014 | 03:40 AM
yishin's Avatar
yishin
Originally Posted by Boma
I don't think the USB stick would have anything to do with the performance of your car, virus or no virus although that scene from Independence Day comes to mind.
Seriously speaking though, our cars should not have any problems running against the Z. The M3 and 5.0s and even modded 3 series are more difficult to predict depending on mods and driver ability, though it is in our favor stock for stock.
I may have missed it somewhere in the thread but what kind of tires are you using? Perhaps you may need a set with more grip. Tire pressure and any extra weight in the car can also influence the performance. I would have to agree with the use of a throttle controller which makes a big difference in throttle response. Use the paddle shifters while in sport mode to get the most out of it.
Good luck, hope this helps.
I am currently using 2014 lexus isf oem tires
Bridgestone Potenza
Old Feb 3, 2014 | 03:43 AM
yishin's Avatar
yishin
Originally Posted by revolut1on
Just disconnect the negative terminal on the battery and reconnect after a few minutes, should reset it.
I find if you leave the gearbox in AUTO it will shift earlier and slower. Make sure you switch to manual shifting next time you give the M3 a run.
Disconnect the battery or pull out fuse chip
Which one safe n better ?
Old Feb 3, 2014 | 03:45 AM
yishin's Avatar
yishin
I guess the best accurate info should be my dyno sheet
I am gonna get my car dyno
What number should i expected ? With the mods i have on ?
Old Feb 3, 2014 | 04:17 AM
9aristo's Avatar
9aristo
i am going to attribute car's agility to driver skill on this one.
just practice maybe?
Old Feb 3, 2014 | 04:49 AM
DrRick's Avatar
DrRick
my advice would head to Dyno Lab in marietta. since youve never had your car dynoed...and youre worried about it compared to other vehicles...that would be the route that i would take. fstpassat has very similar mods as you and got his dynoed there, last week.
your dyno should look similar to his.
Old Feb 3, 2014 | 05:06 AM
fstpassat's Avatar
fstpassat
I have the same mods as you. We could meet up and at least verify that your car pulls like mine. My car dyno'ed 400whp and 376wtq. It also went 12.43@115.6mph so it's is running correctly for the mods. Shoot me a pm if you're interested.
- Michael
Old Feb 3, 2014 | 06:14 AM
DrRick's Avatar
DrRick
I have the same mode as you. We could meet up and at least verify that your car pulls like mine. My car dyno'ed 400whp and 376wtq. It also went 12.43@115.6mph so it's is running correctly for the mods. Shoot me a pm if you're interested.
- Michael
where did you run that time? im planning to go to ATL Dragway in march but im almost certain that i wont be in the 12's on that slow *** track...
Old Feb 3, 2014 | 07:00 AM
fstpassat's Avatar
fstpassat
I ran that time at SDR. I despise Atlanta Dragway even though it is only 45min from me.
Old Feb 3, 2014 | 07:36 AM
DrRick's Avatar
DrRick
nice. and i see that theyre already doing Test and Tunes, as well. i think i'll head out there on the 15th...
Old Feb 3, 2014 | 09:30 AM
yishin's Avatar
yishin
- Michael
Yea good when n where ?
Old Feb 3, 2014 | 10:10 AM
boostftw's Avatar
boostftw
I'm going to recommend you reset the ECU and start driving aggressively so the ecu can relearn how you drive the car. (Start do as many hard pulls as possible)
When I got my headers installed we dyno'd at 365whp... disappointed with our results my tuner called SIKKY and they recommended we do 5-6 hard pulls letting it cool in-between... after that my car kept creeping up 370/385/390 eventually to 400+ whp.
Old Feb 3, 2014 | 11:20 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Wow really ... I had no problem with buying my isf or any issue getting things done in usa so far.. Dont be a fuking ***
If u have no clue how to resolve this **** ..
If u wanna make comments on some ppl background plz just GTFO here n do that **** in local meet and see what happen
This thread has turned around since the post above but yishin I want to make a crystal clear point.
If you EVER physically threaten another member again on our forum you will be banned immediately. That is clearly explained in our terms of service and you will get no other warnings.
Knock off the name calling and cursing as well. If another members post bothers you, use the report a post feature and the moderators will review. In this case you totally misunderstood the members intentions and went off on him for no good reason.
Tom2769
IS F (2008-2014)
38
Jul 22, 2016 09:03 AM
kiryu
IS F (2008-2014)
Sep 29, 2014 12:22 PM
v8sten
IS F (2008-2014)
May 22, 2014 05:43 AM
yishin
IS F (2008-2014)
Feb 8, 2014 05:05 AM
