GI: High Performance IS-F specific Sway bars
Hi all,
given that Hotchkis is discontinuing the IS350/250 sway bar set. We are considering making our own. Rates are still in the consideration phase but I am looking at something to compliment our track setup with a good lateral spring rate that will be noticable with the 16/12 rates we run. The rear on the stiffest setting in the past was mildly felt and I think there is still some improvement to be made. I need to run a large lot to get it done, so I am curios as to how many would be interested as well.
We would include our full endlink set and SuperPro poly bushings and potentially billet sway brackets depending on final diameters.
post up if you would be interested please.
Thanks Mike
Thanks Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
This would be front and rear. Current rates on these bars were
27K front and
8k/12k rear
Goals right now are around 37K front and 16K/22k rear. Another great thing is that we would remove the overbend on the bars and move to a 90 degree bend thus allowing more usable leverage with our MEGA arms because they would be centered over the middle mount point. This would give 6 total usable sway bar configurations for the rear which can me much more influential to bumpsteer and corner trajectory. Currently with our MEGA arms the outmost mounts create a knee response on the sway bar, which is non linear. It would allow a more linear adjustment option. I would also add thrust plates for the bushings because my bar walks all over. I added a rear collar to hold it in one place which seems to be working after several track days..
27K front and
8k/12k rear
__________________
JE
Club Lexus Vendor Marketplace
Dec 28, 2011 08:16 AM
