Aftermarket ISF wheel thread
#107
I don't know if this has been already talked about, but i figured i should ask here, i really want to change my wheels but at the same time i don't know if i should because the wheels on our cars were specifically made for our cars so i don't know if it's a good idea to take them off.
Dattaboi (04-03-24)
#108
well I want to do it for style because the 2011 wheels aren't really the nicest and i just felt bad because they were specifically made for the car but i guess I'm ok now and how much could i sell the stock ones for?
#110
I would suggest you just keep your stock wheels for a backup set, or to return the car to stock if/when you ever decide to sell it. You'll have an easier time selling the aftermarket wheels, and more buyers will want the stock wheels anyway.
#116
The 19s weight .2lb more in the front than factory wheel and .6 more in the rear on a much wider rim... Im very happy with Strasse Forged work. I think ADV1is putting out some wicked stuff these days as well. I do track which is the biggest reason for changing rims. they dont make much in 20 inch tires for track abuse and i was sick of swapping wheels all the time and having my alignment be off.
#117
I love your F with 20"s wheel, especially in the 6th picture your car look sickest that i've ever seen which is in my computer's background right now.
Darbs Can I ask you a question? why do you downside your wheels and tires (the tires looks narrower)?Because of performance? Am I right ?
You know my F is the same color like yours and I go with 19x9 (255/35) front ,19x11(295/30) rear but I feel the rear axle is a bit heavy and I want to downside to 275/35 (strech tire)on the rear only. Do you have any suggestion?
Thanks !
Thanks !
I have also tried the Potenza RE11 and Nitto NT05 both are great tires i like the RE11 & AD08 better than the Nitto but the Nitto is very comparable in performance, its cheaper but it starts with less tread and you replace them to often
#118
[quote=Petshark;7541456]No i tired a set of teins in the first year had my F. hated them and took them off. We really slammed it for a couple pics and brought it back up to a useable height. I like the stock suspension. im going to put a set of swift springs in and see how i like the changes plus it should make the 19s look better
#119
