Aftermarket ISF wheel thread
#437
^^^^Offsets I'm running RCF wheels with the same dimensions - offsets are +50mm front and +41mm rear. Running 255/35/19 front and 295/30/19 rear. Tires are Bridgestone S-04 and the rear fenders are rolled flat. The tires you're suggesting would have an OD that is larger than stock.
Lou
Lou
Vervish (04-09-17)
#445
No fender mods yet. Heard I might need to roll rear fenders but have not had any rubbing at all yet. Haven't had rear passengers yet. Still might roll rear fenders to be safe and might go to 295's in rear for next set of tires. Thank you. I really like how they turned out.
#446
Hi all,
I have a set of Work VS-XXs that are 19x8.5 +40 in the fronts, and 19x10 +48 in the rears. Fronts are R disk, and rears are O disk. I'm looking to get your input/advice on some tire sizes for these on the IS-F. I'm hoping that they won't have any fitment issues or rubbing, both for stock height as well as being lowered, but I'm not sure. I'm also hoping that these will clear the brakes too?
Thanks!
Thanks!
#447
Hi all,
Thanks!
Thanks!
KidAYo (04-14-17)
#448
The version that Flowrider has definitely looks good on the ISF. The fact that you can add bigger tires is even better. The only con is the fact that they're so heavy. I was playing around with the thought of getting a set of 2012 ISF wheels or RCF wheels, but the chances of getting a set without playing the waiting game + the fact that they're relatively heavy pushed me to pull the trigger on these wheels:
Happy to say that 18x9.5 +40 on 265/35 Michelin PSS (all around) functions perfectly on stock height. No rubbing on full lock and no fender mods required. Haven't gone over large speed bumps with people in the back so can't comment on that.
#450
