Painting calipers - has to be high-heat paint?
Old 05-17-12, 12:02 AM
IceIridium
IceIridium's Avatar
Default Painting calipers - has to be high-heat paint?
I wanted a custom color for my calipers.
The shop I was going to get my calipers painted at just informed me they can't mix the color I want in high-temp paint.
Now, does caliper paint HAVE to be high-temp? I don't track the car, just the occasional spirited (eh hem) drives on public roads. I've heard of people painting calipers in standard paint before, I think. But does our Brembos have different paint requirements?
Read on the IS board a member used engine enamel base coat, regular paint mid-coat (for the color) and high-temp clear coat over that on his 350 calipers. Would that suffice? Or is that still a risk?
Old 05-17-12, 12:07 AM
ISF4life
ISF4life's Avatar
its high heat area, High temperature is recommended . If u r only doing for look then is all up to you .
Old 05-17-12, 12:21 AM
Apexsports
Apexsports's Avatar
High temp is recommended for longevity. All of the high heat cycles the calipers go through can eventually crack/chip a standard automotive paint. If you have your painter mix a custom color, he can try adding a bit of flex additive to counteract the paint shrinking with each heat cycle.
We used hi-temp engine enamel on mine. They seem like you could smack em with a hammer and it wouldn't chip off.
Old 05-17-12, 12:39 AM
Weapon F
Weapon F's Avatar
Not only do you have to worry about cracking and chipping but the biggest concern will be fading of the paint over time. I have seen automotive paint fade from .heat overtime
Old 05-17-12, 01:21 AM
IceIridium
IceIridium's Avatar
So how am I gonna do them up a nice custom color then? HMMPH!
Cus looks like all they can mix in high temp are boring colors.
And boring sucks ********.
Old 05-17-12, 11:15 AM
06isDriver
06isDriver's Avatar
I used the silver G2 kit then did a tungsten pearl color match aerosol spray over that, followed up with the Lexus decals and a high temp clear.
The paint specialist told me that this automotive paint is tested to at least 300F, so I feel pretty confident that the G2 epoxy I laid down and high temp clear coat over that will provide plenty of protection.
Old 05-17-12, 02:55 PM
mugenh22a4
mugenh22a4's Avatar
What, you want neon pink? Or puke green metallic?
Old 05-17-12, 03:10 PM
M K S
M K S's Avatar
I know several people who used non-high temp paint, and their calipers "appear" to still be holding up just as good as when they sprayed them.
Old 05-17-12, 04:51 PM
2ndGF
2ndGF's Avatar
Apex I will bring a hammer on Sunday, let's see if your paint chips ;-)
Old 05-17-12, 07:19 PM
IceIridium
IceIridium's Avatar
Ok you got me, it's quite a bit more boring than those colors... metallic/pearl yellow.
Old 05-17-12, 07:59 PM
Apexsports
Apexsports's Avatar
Lol the keyword there was "seem"...not looking to test out the theory anytime soon.
Old 05-18-12, 06:54 AM
vintage
vintage's Avatar
I painted mine with a high temp spray paint with ceramic and they look like they were done at a bodyshop. Then added Brembo decals in black and they are turning heads everywhere as my car is Obsidian. It is a nice yellow and we will see how well it holds up. So far its excellent.
Old 05-18-12, 08:22 AM
Weapon F
Weapon F's Avatar
Just contact G2 they can color match any automotive paint color as long as you have the paint code so find car color that you like get code and have them make you custom color you will pay more for this but in the IMO is smartest way to go
Old 05-18-12, 08:38 AM
06isDriver
06isDriver's Avatar
I wasnt too pleased with the G2 silver kit they had. I tried putting it through an aerosol sprayer but it was too thick, and after I finished brushing it on, it looked pretty bad with clumping of the metallic pieces. I'm glad I had an aerosol body color spray to put over that or I would have been VERY disappointed with how they came out.
Old 05-18-12, 10:36 AM
IceIridium
IceIridium's Avatar
Yeah I looked into G2 but the stuff comes in a jar for you to brush on. Great for traditional calipers with rough textured surfaces but not on our smooth surface brembos. Ours need to be sprayed.
Also found automotivetouchup.com and they'll mix any color in a spray can but not high heat.
One option I'm looking at is Duplicolor metalcast yellow, takes up to 500deg F... but the samples I've seen of that is a bit of a greenish/gold hue not the pure yellow I want.
Quick Reply: Painting calipers - has to be high-heat paint?
