Inner Tire Wear
Hi everyone, I know there's a lot of posts about this already but as I was reading I confused myself even more. I have about 8000 miles on my bridgestones and I think in about another 1000 miles the tires are gone, so I want to prevent that from happening again by fixing the camber? What is the cheapest solution to setting the camber to 0, or as close to 0. I have KW v3's and they're dropped pretty low so the cars camber is even more negative. Can I just buy the toe link and im good to go? thanks guys.
I got the same issue...http://circuitmotorsports.net/spc67530.html This is said to be able to fix the issue, never tried it so I dunno if this is 100%
didn't you see this mentioned a few times in your research?
http://shopfigs.com/v1/index.php?rou...&product_id=58
Why not go positive camber? Really, all this leaning the wheel inward to help front end traction is a waste of time. Just set it up like a Conestoga wagon with lots of positive camber and all your problems will be solved.
Oh, forgot to mention. You'll still have inner edge wear issues. But since so many here seem to be convinced this is a camber problem I really think someone needs to try this. No, it won't be me.
shortbus19
Wheels, Tires & Brakes Forum
19
Nov 20, 2019 04:03 AM
RocketGuy3
Suspension and Brakes
24
Jun 13, 2010 01:14 PM
gman44116
Jan 4, 2010 08:32 PM
