Brake Pads
Old Dec 2, 2010 | 10:46 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by zojirushi
I just received my order of front and rear Bobcat pads. Did I make a mistake by ordering them? What kind of issues will I experience with the current iteration?
Inspect them carefully. There should be no pad material on the lower edge below the backing plate. The top of the pad material when installed should have about 2mm of disc face showing. Current iterations have 4mm or so which leaves a pretty large unused band at the outer edge of the disc.
Your pads may be OK, you just need to compare them to your OEM pads to be sure they're going to work right. If they're not right, send them back to Carbotech.
Old Dec 2, 2010 | 01:49 PM
Bulls23337's Avatar
Bulls23337
Question
Originally Posted by Juanca
^^^ They are not. Sure there is no dust and for just casual driving they're fine, but if you drive hard and/or like to go to the track (and I'm talking about drag strip, not even road course) you'll notice that they fade quickly.
Yeah I'm not tracking the car or anything so I'm not too worried about fade as much. I use the car for spirited drives. Next time I'll look into the Bobcats or a different set of Hawk pads, unless I can sell these Hawk Ceramics and get something else.
Infamous3
Jul 29, 2021 08:18 PM
DorianE
RC - 1st Gen (2015-present)
Jan 8, 2017 04:18 AM
heyitzalex
May 3, 2010 07:50 PM
JBasco20
Feb 26, 2010 07:28 AM
kingloose
Suspension and Brakes
Jun 14, 2005 04:41 PM
