Official IS-F Drag Time/Dyno Time/Performance Thread
Old 04-12-15, 09:53 PM
  #526
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,076 Likes on 2,470 Posts
What tires were you running? 17 psi is way too low for any street tire.
Old 04-13-15, 05:35 AM
  #527
lifethinkr
lifethinkr's Avatar
bridgestones. I was thinking about this all might. I think I didn't power brake it enough. I was actually launching around 14-1500 rpm. I think next time im going to try to power brake as much as I can before the tires brake loose. so the car can get up into its power band faster. the track was prepped really well so im not worried about losing traction.I should have been into the 8s. and I will try 25-27 psi in the rear tires.
so ISF's don't have a pedal dance?
what is everyone launching at to get a 1.9 60ft?
Old 04-13-15, 05:09 PM
  #528
lobuxracer
Tech Info Resource
lobuxracer's Avatar
They do, but there is no advantage to the pedal dance in an F. Press and hold the VSC switch, and you are in the best possible configuration.
Old 04-14-15, 04:34 AM
  #529
Gymkata
Gymkata's Avatar
I got a best of 1.8xx 60 ft on 275/30R19 Michelin PSS tires launching at 1000 rpm, and long push (not pedal dance...no reason to). This was with a good DA, good track conditions, headers and exhaust...but before I got my OS Gikken. I'm curious to see how I could do on street tires with it.
Old 04-14-15, 06:31 PM
  #530
ToothDoc
11 Second Club
ToothDoc's Avatar
Why would an LSD help with a launch if you're not slipping anyways. It won't. Sorry. Less weight and sticky tires, lower diameter = shorter 1st gear, and DA, and short staging will give you better 60' in the IS-F.
Old 04-14-15, 08:17 PM
  #531
Gymkata
Gymkata's Avatar
That makes sense. It is probably easier to hook up consistently now, but when I had my best runs I was hooking up perfectly anyway.
Old 04-17-15, 07:02 PM
  #532
Justind27
Justind27's Avatar
Default 1st official drag runs in my F
So this is my 1st EVER timed drag runs, more special cause it was in my F! This is just 1/8th mile
1st run
2nd run
Old 04-17-15, 07:22 PM
  #533
YotaLex
YotaLex's Avatar
Sweet! What did you run against?
Old 04-17-15, 07:46 PM
  #534
Justind27
Justind27's Avatar
1st was a 5.0 fox body 2nd a compound twin cummins (buddy of mine, 4wd launch)
Old 04-17-15, 09:43 PM
  #535
Justind27
Justind27's Avatar
Hey so I was talking to a few of the experienced locals here and this is not a true 1/8th mile due to the run being about 110 feet short of a 1/8th due to the size they can run the setup. Either way, I had a blast and finally getting experience with draggin and getting numbers for the guys curious on the actual difference of the carbon driveshaft vs stock.
Old 04-18-15, 02:41 AM
  #536
chrisp1
chrisp1's Avatar
That's a weird slip! Your time is really fast but mph is really slow
Old 04-18-15, 10:46 PM
  #537
Justind27
Justind27's Avatar
Thanks for relocating, my bad.. The 2nd run I was alil hesitant and about half way through 2nd gear I grabbed the paddle into 3rd gear, hence why the other vehicle (buddy's cummins dodge) won. My cars mods: carbon driveshaft, Joez exhaust w/ titanium mufflers, takeda intake, custom intake scoops, Braille 21 lb battery, custom rear subframe braces, other various stuff removed to make my car at 3600 lbs w/ 1.5 gallons fuel. Nitrous in the works but still a couple small items left to do.
Old 04-29-15, 04:44 PM
  #538
abohler
abohler's Avatar
Not bad #'s for now. Made a few extra changes, hoping numbers are closer to 550
File Type: bmp
Old 04-30-15, 06:01 AM
  #539
BS ISF
BS ISF's Avatar
nice numbers!
Old 04-30-15, 07:14 AM
  #540
VtotheJ
VtotheJ's Avatar
If anyone wants M&H Racemasters mounted on TRmotorsport C2 rims like new for $600, head over to the thread below. Only a few passes with them. I ran a 12.3 with them last year. Only mods were muffler delete, throttle controller.
https://www.clublexus.com/forums/whe...t-c2-rims.html
Quick Reply: Official IS-F Drag Time/Dyno Time/Performance Thread
