IS-F Replacement tires size
Old Feb 21, 2008 | 05:36 PM
ChuH's Avatar
ChuH
Default IS-F Replacement tires size
I spoke to my dealer and explained that I would like to get wider Michelin PS2 tires. They offer to buy back the OEM tires when my IS-F arrives in April. What size can I fit on the stock rims? I know that the front is 8" (225/40R19) and rear 9" (255/35R19) wide. I am guessing the replacement tire I can use is 235/35R19 and 265/30R19. Is this correct? I would like to run wider but the stock rims are already too narrow. I like the look of straight vertical sidewalls. I dislike the stretch look the current IS-F stock tire looks. If I go wider like 245/35R19 and 275/30R19 maybe to wide for the rims. I don't like the buldging look either. Appreciate any suggestions on the proper size of tire I should use.
Chu...
Old Feb 21, 2008 | 10:49 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Wheel opening size is identical with the regular IS250/350. The front fenders are actually a lot wider than the rear quarter panels at the wheelhouse.
josh810
IS F (2008-2014)
May 30, 2016 11:15 AM
IS250JAZZ
Mar 21, 2013 10:04 PM
s4play
IS F (2008-2014)
Aug 27, 2009 11:05 AM
LEXUSF
Wheels, Tires & Brakes Forum
Feb 16, 2009 06:57 PM
ChuH
Mar 12, 2008 10:18 PM
