Why didn't they put on wider rims! :(
Old 09-12-07, 12:43 AM
ES3
ES3's Avatar
Default Why didn't they put on wider rims! :(
Would it have been that difficult for Toyota to give us just an inch up front and in the rear more than what we can already get on the ISX50?
Old 09-12-07, 04:34 AM
ChuH
ChuH's Avatar
Maybe because Lexus want to get higher gas mileage by using narrower tires to avoid gas guzzler tax. Wider tire and rims equals heavier weight and drag/resistance.
Chu...
Old 09-12-07, 08:47 AM
Da Hapa
Da Hapa's Avatar
Probably because they're not necessary for anything but Bling and Toyota/Lexus probably thinks that anyone who is concerned about the curb appeal more than the actual performance value of the wheel is going to go aftermarket anyways.
The damn thing is going to be heavy enough as is. If it doesn't need wider, heavier wheels and tires... than I say good for them for not succumbing to the knee jerk reaction.
Old 09-12-07, 11:05 AM
aco
aco's Avatar
If you don't think Lexus is concerned with Bling, than take another look at the LS series with that chrome strip running across bottom of the doors. I saw up close at TOL and the response from the friend I was with was, "Today, Bling sells."
Old 09-12-07, 12:05 PM
4TehNguyen
4TehNguyen's Avatar
the new M3 tires arent that much wider, if any, over the 335
Old 09-12-07, 02:32 PM
05RollaXRS
05RollaXRS's Avatar
Received 2,421 Likes on 1,743 Posts
275 mm in the back and 235 mm at the front (19 inches rim size).
Old 09-12-07, 07:30 PM
vip3r1850
vip3r1850's Avatar
Thats the size that i suggest if you go aftermarket rims, you can squeeze the 245 up front, its alot easier to find more tires in a 245 than 235
Old 09-13-07, 07:36 AM
aco
aco's Avatar
If you are referring to the tire size of the E92 M3, according to the latest issue of R&T, 10/2007, the tire specs are:
F: 245/40/18
R: 265/40/18
Old 09-13-07, 09:18 AM
05RollaXRS
05RollaXRS's Avatar
F: 245/40/18
R: 265/40/18
I was referring to the optional performance package (no M3 owner seems to be picking the standard 18 inch rims because they are too ugly and bland. The 19 inch optional rims are amazing). The tire size on the 19 inch rims is bigger than the 18 inch rims.
But, yeah the front size is 245mm and not 235mm.
Old 09-13-07, 10:31 AM
dgsvt
dgsvt's Avatar
This is from the CarandDriver M3 review
"The standard Michelin Pilot Sport PS2s are 245/40ZR-18s in front and 265/40ZR-18s in the rear; 19-inch wheels and tires with the same tread width are optional."
245/35-19
265/35-19
The tire width is no different than the 18's...
Old 09-13-07, 10:50 AM
05RollaXRS
05RollaXRS's Avatar
245/35-19
265/35-19
OK my bad. It is 245mm front and 265mm back, not 235mm front and 275 mm back.
But, I did compare 18 rims M3 with 19 inch rims back pictures and the stance of the 19 inch rim M3 from the back seems to wider and intimidating than that of the 18 inch rims.
Possibly the rim width could be different or just the offset (18 x 8 front and 18 x 9 back, 19x 9 front and 19 x 10 back). Then again, I could not find any stats on the 19 inch rims.
Old 09-13-07, 09:31 PM
t0e
t0e's Avatar
I think it was Cost factor.
Old 09-14-07, 04:21 AM
IS350jet
IS350jet's Avatar
245/35-19
265/35-19
Actually, the 19's would be wider. The 19's are a 35 series tire while the 18's are a 40 series tire. As far as aspect ratio is concerned, the 19's are wider.
Old 09-14-07, 04:37 AM
dgsvt
dgsvt's Avatar
The aspect ratio has to do with sidewall height not the width of the tire. The width is the first number in mm. So for the rear M3 tire 265/35-19 =
265mm wide= 10.43 inches wide
265*.35 = 92.75mm sidewall = 3.65 inches sidewall
19 = rim height
19 rim + 3.65 top sidewall + 3.65 bottom sidewall = 26.3 overall tire height
so... 10.43" wide 26.3" height
If we use the 265/40-18 we get the same width tire 265mm
265mm wide
265 * .4 = 106mm sidewall = 4.17 inches sidewall
18" rim
18" rim + 4.17" top sidewall + 4.17" bottom sidewall = 26.34 overall tire height
so 10.43" wide 26.34" height
Both tires have almost the same overall height, but the exact same width.
Old 09-14-07, 05:08 AM
ChuH
ChuH's Avatar
So what is the ideal tire size for the IS-F rim? I am thinking of change it once I get the IS-F. Don't like the stock look.
Chu...
Machine13
10-04-15 09:22 PM
Hill60
GX - 1st Gen (2004-2009)
28
03-11-14 12:14 PM
GRPFAN
Wheels, Tires & Brakes Forum
03-08-14 02:42 PM
Harlemboi
06-02-11 08:56 PM
MrG4Life
08-19-06 02:50 PM
Quick Reply: Why didn't they put on wider rims! :(
